Transmission
Old Apr 6, 2013 | 12:03 PM
Rrassi300zx's Avatar
Transmission
Hello zdrivers, I have a 1990 300 zx NA automatic, my transmission shifts hard into 2 gear almost like a jerking motion, it also seems to shift a little late, but it does shift in all gears, any advise before going to transmission place?
Thanks ahead of time
Old Apr 6, 2013 | 12:17 PM
Check the ATF level and color...
Old Apr 6, 2013 | 03:06 PM
BlueKitsune's Avatar
Intrawebz Wizard
Yup, do was Nismo said! Make sure to check it with the engine running and trans in park to get a proper reading.
Had a friend drop off his 300ZX the other day with a similar problem. He told me he topped off the trans but when I checked it it was nearly 3 quarts low!
Old Apr 6, 2013 | 03:28 PM
PredatorZ's Avatar
Replace filter
Wouldn't be a bad idea before you add anymore fluid to take it in for a service, have the filter changed and all new fluid added. Who ever does the service can tell you if there was a lot of metal debris in the filter. Then you will have a little better idea where you set.
Old Apr 6, 2013 | 09:43 PM
Thanks for the advice, I will check the ATF fluids in the morning and if it still shifts hard the next step would be to replace the fluids and filter, I hope this works, thanks again.
Flacster
Oct 20, 2010 07:34 PM
zfreak1981
Feb 2, 2010 07:20 PM
JDsmash
Dec 22, 2006 07:00 PM
TAdam2000
Nov 23, 2002 11:18 PM
BadfishZ
Oct 8, 2002 04:40 AM
