A/C issues...
Old Jun 28, 2004 | 02:08 AM
Riz Z Speed's Avatar
Administrative Brown Guy
The temp goes down cuz you're moving and moving forces air over the radiator and cools the car's engine and other parts.
Sounds like the A/C is finally running out of R12 refridgerant. You might wanna look into having your car retro fitted to the newer R134 refridgerant.
Old Jun 29, 2004 | 08:52 PM
if you're experiencing the same problem even after the recharge, either you're have a leak somewhere or the compressor is going. Have your mechanic check it out.
Old Jun 30, 2004 | 11:34 AM
91zxtt's Avatar
If it's blowing humid air, then your AC drier may be clogged or on it's way out. The drier is fairly inexpensive, but like most parts on this car, the labor to install it will be expensive. If it's your compressor, then search junkyards. You could probably pick 1 up for $150 or so.
GreenMachine
Aug 10, 2012 07:04 AM
Zfanattic86
14
Jan 14, 2008 11:10 AM
duowing
Sep 21, 2007 07:10 AM
88blanca
Jun 29, 2005 01:34 PM
Ravin
Jun 26, 2005 06:35 PM
