whats left?
Old Oct 28, 2006 | 08:59 AM
drkfilldschemis's Avatar
whats left?
im replacing my head gaskets
and i alreadly took out the head bolts
and unbolted the exhaust
what else is there for me to do to get off the heads so i can replace them?
Old Oct 28, 2006 | 09:49 AM
Remove anything else in the way.... wiring... belts... brackets.... hoses...
Please say you have a Haynes Manual
Old Oct 28, 2006 | 10:03 AM
i removed all the hoses and wires i could see
i can on the left side move it and wiggle it so i think thats all unbolted
but the timing belt-bracket?= is connected to both
and the other one is budging
is there sumthing im missing on the underside ?
or is there sumthing just hidding im missing
or is it an obvious thing?
Old Oct 28, 2006 | 05:50 PM
johnZboy's Avatar
Distinquished Guest
Just in case you haven't noticed, the heads are connected to each other via a timing belt. Since your post doesn't mention that the timing belt has been removed, I thought it worth bringing it to your attention.
The intake must also be removed. Again, you didn't mention this was already done.
You should be at this point (with the timing belt rear cover plate also removed) before attempting to remove the heads.
Also, if you don't already have a Haynes manual, go drop the $20 to get one. Best investment you'll make if you plan on doing a lot of your own work.
Old Oct 29, 2006 | 04:54 PM
thanx a lot man that helps a lot
also how do i get off my pulleys that turn both ways?
liek i can't get it to stay still to unbolt it
Old Oct 29, 2006 | 04:56 PM
im almost to that point
do i have to take off my exhaust or can u just unbolt it
i unbolted it and was told it'll be fine and jsut dangle there
and yes i told off the timing belt
Old Oct 29, 2006 | 08:05 PM
No offense (I really mean this in a nice way)... but it sounds like you have no idea what you are doing. Have you ever rebuilt (or even taken apart) an engine before?
Old Oct 30, 2006 | 04:58 PM
hey i got a question to add on to this
wat is the name of the speciality tool im gonna need to take of the pulleys on the engine?
can someone provide a link?
Old Oct 30, 2006 | 06:39 PM
A ratchet? The ratchet will help you remove all accessory pullies... A pulley removal tool aka "Pulley Puller" will help remove the crank pulley.
Old Oct 31, 2006 | 04:37 AM
ight thanks thats exactly what i needed
CharlieZ
Jul 6, 2008 07:12 PM
craigerd2
Apr 29, 2003 04:03 PM
kev metz
Mar 24, 2003 02:09 PM
diehard300ZX13
Sep 29, 2002 09:39 PM
f1apex
May 15, 2002 08:26 AM
