Maxima alternator swap into '86T
Old May 13, 2008 | 02:04 PM
ern's Avatar
ern
I finally was able to get a '92 maxima alternator from the junkyard, I was so excited that I didn't look or get the VIN to confirm if it was a SOHC or DOHC....does it matter???
The guys at the local alternator shop is telling me that only the SOHC voltage regulator would work with my Z....is this true?
Old May 13, 2008 | 02:18 PM
Lots of info on the intrawebs about this swap:
http://300zx.tombeauchamp.com/04_11_...ternator.shtml
http://www.az-zbum.com/modification....ternator.shtml
Does the alternator look like this?
Hopefully you didn't pay much for that junk yard alternator... you never know what kind of "deal" you're getting until install.
Old May 13, 2008 | 02:34 PM
ern's Avatar
ern
Ya, I've already read both write ups before many times, but neither mention whether SOHC or DOHC is a factor... I just got caught off guard when the guy at the alternator shop told me it did matter. So I guess it's safe to assume that if Zbum did mention it in his write up then I shouldn't worry about it????
Old May 14, 2008 | 03:50 AM
AZ-ZBum's Avatar
What do you need the VIN for? You just have to look at the motor.
Oh, and no 92 Maxima came with a DOHC VG motor in North America. So to answer your question. No. It doesn't matter what VG powered Maxima you pulled the alternator from. They're all SOHC. And yes. Only the SOHC will be a simple swap.
HOWEVER! There was a VE powered Maxima that was DOHC. But if you can't tell the difference between the two motors, you probably need to learn to pay more attention to what you're doing.
lheggS130
Jan 26, 2013 01:24 AM
Niku-Sama
Sep 3, 2008 06:59 PM
300zChick
Jun 16, 2005 07:10 AM
AZ-ZBum
May 31, 2002 01:55 AM
killermonkeys
Jul 22, 2001 05:56 PM
