Loose Wire by the drive side fuel injector 84 Turbo
Old Jul 1, 2018 | 07:19 AM
doboy_1's Avatar
Good Morning,
I am restoring 1984 Nissan 300zx turbo. On the drive side, wire harness that holds the fuel injectors wire there is one single wire with female connector that I have no idea where it go to if anyone got 1984 or 1984 can you please tell me where this wire connect too. Attach is the photo of the wire. thanks again !
thanks D
Attached Thumbnails Loose Wire by the drive side fuel injector 84 Turbo-300zx.jpg   Loose Wire by the drive side fuel injector 84 Turbo-wireissue.jpg
Old Jul 2, 2018 | 05:59 PM
JSM's Avatar
JSM
That looks like the trigger wire for the AC compressor. They integrated some other wires into the EFI harness that then plugs into the main body harness.
Old Jul 3, 2018 | 03:17 PM
doboy_1's Avatar
Thanks I was thinking the same thing but AC compressor is connect to another wire. Going to attach another photo
Old Jul 3, 2018 | 05:33 PM
JSM's Avatar
JSM
Ok. It may be to the sensor on the lower intake for the injector fan cooler than. It should be between cyl 2 & 4 right behind the distributor.
Other wise check the wire colors and bust out the FSM on Xenon and check the wiring diagrams.
Mojobaby27
May 8, 2023 03:09 PM
doboy_1
Jul 7, 2018 02:26 PM
statzera
Jul 14, 2017 02:13 AM
87_silverz31
Apr 21, 2012 06:12 PM
Turbo86
May 9, 2007 08:20 PM
