Loose Wire by the drive side fuel injector 84 Turbo
2 Attachment(s)
Good Morning,
I am restoring 1984 Nissan 300zx turbo. On the drive side, wire harness that holds the fuel injectors wire there is one single wire with female connector that I have no idea where it go to if anyone got 1984 or 1984 can you please tell me where this wire connect too. Attach is the photo of the wire. thanks again ! thanks D |
That looks like the trigger wire for the AC compressor. They integrated some other wires into the EFI harness that then plugs into the main body harness. |
Thanks I was thinking the same thing but AC compressor is connect to another wire. Going to attach another photo
Ok. It may be to the sensor on the lower intake for the injector fan cooler than. It should be between cyl 2 & 4 right behind the distributor. Other wise check the wire colors and bust out the FSM on Xenon and check the wiring diagrams. |
