Fuel Pump
Fuel Pump
I have a problem with my 85 NA. I started it up the engine shakes, runs choppy, when I go to excelrate it gets worse, then she stalls, could that be a fuel pump problem ? I drove it all day with no problems.
check your TPS and maf first if they check out ok for the most part. Buy a good ole can of fuel injection cleaner and maybe some octane booster. Try to keep track where you buy gas from and see if the problem comes back.
I agree with Navy in a way, but first when was the last time you changed the fuel filter? also if you recently washed the engine maybe you have water by the spark plugs and the wires could be bad. these cars being 20 years old, I recommend to drop the fuel tank and clean it as they build up sluge over the years.
Ok replaced the fuel filter, added octane booster, she still won't idle. The car is getting fuel, when I pulled the filter off fuel came out. I have this strange feeling that is might be starving for AIR !!!! Any suggestions ??? LOL I guess I am taking the new Trek Bicycle to work, not to say thats bad, I live in SUNNY South Florida and look at the good thing, I ain't burnin gas .
Iddle issue
ThatDude114
Jun 15, 2014 08:43 AM
sameerb1
Mar 20, 2011 05:21 AM
mrprofile
Jun 25, 2010 11:23 PM
ern
Oct 20, 2006 07:01 AM
