Bog when hit throttle or going up hill
Old Jul 28, 2018 | 05:50 PM
300zxrailboss's Avatar
Alright guys having some issues with my 86 300zx NA. I've changed timing belt, thermostat, water pump, temperature sensor and rotor. Cap, plugs and wires are fairly new. I've changed tps sensor and when I start car it idles at about 700 rpm. When try to give it gas to say haul as it'll just bog and slowly gain speed. Also when going up hill it'll start slowing down. No ecu codes on dash so any help will be great
Old Jul 29, 2018 | 10:03 AM
Ok so update ecu codes came up as 11, 23 and 31
Old Jul 29, 2018 | 10:25 PM
Welcome to ZDriver!
Have you checked the timing? Fuel pressure? Read the spark plugs?
Did you drive the car then check the codes?
Old Jul 30, 2018 | 03:27 AM
Last night I power washed underneath hood and degreased everything and then car wouldn't let me rev past 2500. Pulled over let everything dry off pulled connector off maf, reconnected it and car ran perfectly. Like a whole new car!
Old Jul 30, 2018 | 03:32 AM
How does that even happen
90NA300ZX
Sep 11, 2016 08:21 PM
morbidrazor
Jun 5, 2011 09:17 PM
Kronic_C
Feb 20, 2010 09:13 AM
KO1290
Oct 29, 2009 10:39 AM
Charliegsxr
Jul 20, 2009 07:43 PM
