Car won't stay runing
Old Oct 25, 2009 | 09:56 AM
KO1290's Avatar
My 85 300zx wil start but won't stay running. I've checked the fuel pump, and installed a new fuel filter. I checked the cap and rotor, the seemed fine. Not much spark either
Old Oct 25, 2009 | 11:51 AM
Welcome to ZDriver!
Have you checked the ecu diagnostic codes? Checked all the sensors and connections (mainly the MAF, TPS, and CHTS?
Did the car used to run good? When did it start having probs?
Old Oct 27, 2009 | 10:42 AM
KO1290's Avatar
Unhappy
No, I didn't check the codes, I don't think there is even a computer.. It ran perfict then it sat for 3 hours and it rained. when I went to start it back up it idles for 2 seconds at 1k then just died down... I just installed a new Mass Airflow Sensor but its still doing the same thing. I can unplug the mass airflow and it accually stays running but will not go over 2000 rmps..weird huh?
Old Oct 27, 2009 | 11:38 AM
es de uh, if the car is fuel injected, it has a computer... where do you think the wiring to the Mass Air Sensor goes? Click: http://www.duglin.net/zcar/z31/z311586t.htm
Your TPS is wet (did you drive it in the rain?). Pull the plug, blow dry it, re-install.
Old Oct 27, 2009 | 06:24 PM
KO1290's Avatar
Angry
That was my next try, the TPS, the new one is coming in tomorow. I don't think I can use that link because it's a non turbo but i'll give it a try either way, it's appreciated for the responces!! i'll give it what I got!
Old Oct 27, 2009 | 06:56 PM
It doesn't matter if it's a turbo or n/a... same procedure...
http://z31.com/oboard/archives/view.pl?151
And you don't need to replace the TPS... just clean and dry it.
Old Oct 28, 2009 | 11:00 AM
KO1290's Avatar
The new one didn't work... It backfired through the Mass air flow, white... so it may be out of timing for some odd reason, wasnt too long ago that a new timing belt was put on, could it have gone into safe mode?
Old Oct 28, 2009 | 12:51 PM
aye aye aye! Am I talking to a wall?
Run the ecu diagnostic test.....
Old Oct 28, 2009 | 01:54 PM
fdc_guy's Avatar
Nissans Purist
/me is a brick wall also.
Old Oct 28, 2009 | 02:24 PM
Old Oct 28, 2009 | 03:04 PM
KO1290's Avatar
Im sorry, not a wall haha im going to as soon as possible, since the car dicided to die out a few miles away from my house i have to manage to get there to work at it, i'll run a test, could it be CHTS?
Old Oct 29, 2009 | 09:49 AM
KO1290's Avatar
what does the test selector look like and were is it located. i looked on google but no luck. thanxs again
Old Oct 29, 2009 | 10:39 AM
First google result: http://www.nissanforums.com/z31-300z...z31-codes.html
or you could look it up in your Haynes manual or FSM.
86300zx
Nov 14, 2012 08:08 AM
smurffz32
Sep 26, 2012 11:49 PM
dan121
Feb 1, 2012 04:41 PM
Tak_Z32TT
Apr 24, 2006 10:35 AM
oakdalenewbies
Aug 31, 2003 10:21 PM
