Loose Wire by the drive side fuel injector 84 Turbo
Good Morning,
I am restoring 1984 Nissan 300zx turbo. On the drive side, wire harness that holds the fuel injectors wire there is one single wire with female connector that I have no idea where it go to if anyone got 1984 or 1984 can you please tell me where this wire connect too. Attach is the photo of the wire. thanks again !
thanks D
thanks D
Ok. It may be to the sensor on the lower intake for the injector fan cooler than. It should be between cyl 2 & 4 right behind the distributor.
Other wise check the wire colors and bust out the FSM on Xenon and check the wiring diagrams.
Mojobaby27
05-08-2023 03:09 PM
