'86 300ZX turbo frustrating missing, pulling andlost of power below 2000RPM
Old Sep 24, 2013 | 08:53 PM
pneftali72's Avatar
Angry '86 300ZX turbo frustrating missing, pulling andlost of power below 2000RPM
Well I bought it from the original owner that keep it in very good running condition, now is mechanical thing that our mechanic can't find. the car starts well in the morning, and it does not shut down however it starts to miss like is running out of gas and it has no power. I tried to accelerate but it miss like is going to shut down but it doesn't. Another important point is that I applied pressure to the fuel line located by the fuel filter and found it full but with a pumping effect much like a hydraulic hose under pressure. I also replaced the EGR vacuum valve solenoid because there was no vacuum pressure, other than that I haven't done anything else. I downloaded the manual from Xenon and I found a Hines manual in order to educate myself but expert advice from some of you will be greatly appreciated.
Old Sep 25, 2013 | 09:37 AM
rogerz's Avatar
Grumpy & Helpful
so this:
Clean the connectors for the maf or afm, ecu and tps. Deoxit by CAIG is probably the best connector cleaner on the market. spray with CorrosionX after cleaning and before putting together this will help prevent any further corrosion.
and check your fuel pressure with a gage! Also check for vacuum leaks again with a gage.
The other two likely causes are a bad chts or bad 02 sensor. cheap enough to just replace both if you can't test them according to the manual.
Old Sep 25, 2013 | 08:12 PM
pneftali72's Avatar
thank you Rogerz, I will work on all this remedies this weekend. Just one more thing, when I conducted a test of the fuel pressure hose I felt that the hose as well as the fuel filter felt like a pumping hydraulic hose under pressure when the car was running. It felt weird so I replaced the fuel filter today but the pressure continued so is the main problem. Does this pumping feel makes any sense to you?
Old Sep 25, 2013 | 10:32 PM
cords z31's Avatar
I have pulsing on my 84 turbo, I also changed the fuel filter because I bought the car and was just doing maintenance and it still pulses, I believe this is normal, if not let me know lol. my car will run fine other than a high idle issue
Old Sep 26, 2013 | 05:07 PM
ndj's Avatar
ndj
-Is it ok once its warmed up? = yes, replace chts and subharness. This is the result of a failed enrichment process that should take place during the cold start. Its a lean condition the engine is experiencing that you feel like is a miss. This can sometimes be solved after several restarts on a cold morning or using very very little starting fluid.
Old Oct 3, 2013 | 07:44 AM
pneftali72's Avatar
Thank you Rogerz,Cords z31 and NDJ for your advice. If there is anything else that you may want to share with me please do. Thanks to your input I was able to troubleshoot part of the problem and the car is running better, in fact I was able to drive it today to work and climbed a big hill, but still have some missing along the way. So far I got the battery tested in three different locations and it checks out ok, I was able to clean up the maf, ecu and tps. All vacuum hoses are fine and there is no sign of vacuum loss.
Becuase I cant test some of the sensors I ordered the chts and O2sensors like Rogerz suggested. I feel that the fuel pump is not working properly and I can hear the sound of the fuel pump therefore I ordered one from 300zxpartsforyou.com/. Now has anyone experienced a clogged fuel line before? Will that be a recommended step before replacing the fuel pump?
blackbetty300zx
Jun 16, 2015 09:37 AM
straight hate
Apr 12, 2007 03:10 PM
flightforlife07
Jul 21, 2006 07:10 PM
snwbrderphat540
Jan 6, 2006 02:44 PM
