VG30ET head question
Old Jan 9, 2007 | 08:05 AM
one_fast_300zx's Avatar
this has prrobably been covered but i cant seem to find it so here goes, i was thinking about using the schiender valve springs,and JWT camshafts in my VG30ET but the cams decription on every site i find says that they MUST be used with JWT valve springs. i dont want the jwt valve springs because its only the outer valve springs. so im curious if anyone knows if i can use the JWT cams with the scheinder valve springs, or if you have a better setup tell me where to get it. thanks alot.
Old Jan 9, 2007 | 08:14 AM
johnZboy's Avatar
Distinquished Guest
Lightbulb Here's a novel idea...
Get the entire package from Schnieder. They can/will grind cams to whatever lift and duration specs you need. Why mix so many engine part vendors?
Old Jan 9, 2007 | 08:54 AM
i was thinking about that but im not that good at figuring out what specs i would need, im still learning alot about things like that.
Old Jan 9, 2007 | 10:34 AM
johnZboy's Avatar
Distinquished Guest
Thumbs up Help for the rookie...
Assuming we're talking turbos, this grind will work nicely. The idle is a little ragged, but sounds nice. I can't say for sure about any performance gains because I didn't add one piece at a time with dyno runs to verify differences.
I also use the Schneider SS valves, and, their springs. Won't float a valve, per their claim, up to 10,000 rpm. I can't verify that either.
Old Jan 9, 2007 | 10:53 AM
ok i saved the pic for my reference and i might end up using it. so you went with that grind+schneider valve springs+SS schneider valves right? just checking to make sure. if this setup works as good as yo say i just may end up going this direction. can you also tell me where you went on the net to order this setup. i realize the cams that are in the car now have to be sent out to be reground but i would like to see the site for myself where you got yours. thanks.
Old Jan 9, 2007 | 11:06 AM
johnZboy's Avatar
Distinquished Guest
Cool Last time I hold your hand today...
Dude... You buy Schneider stuff from SCHNEIDER.
Call 'em... Talk to 'em... They're waiting to serve you (and take your $$$$$...)
Later...
Old Jan 9, 2007 | 11:09 AM
thats what i was looking for. i was on the once a while ago but couldnt find it again, then again as carlos mencia would say im a "dee dee dee" when it comes to remembering things. thats why i usally write everything donw. thanks again.
Remington115
Sep 26, 2012 07:07 AM
ZZzzz
Sep 3, 2012 10:43 PM
283zxt
Aug 1, 2004 07:50 PM
Adz260
Oct 14, 2003 08:39 PM
Meakin
Oct 25, 2001 12:41 AM
