turbo issue new to 300zx
Old 03-24-2015, 10:42 AM
blackbetty300zx's Avatar
I just got a 88 300zx turbo 5 speed runs good besides the turbo gauge sits at - 7 and only moves up to 0 nothing in the + range. Is this normal for a stock car or is there a problem some where? The previous owner was saying something about the waste gate staying open. Any input would be great. Also what plugs and wires do you guys like to run in theses cars? I want to do a tune up. Thanks
blackbetty300zx is offline
Old 03-24-2015, 01:04 PM
Welcome to ZDriver!
That's a usual sign of a dead turbocharger, but do some checks first... Can you hear the turbo spool at all when you punch it full throttle? When driving does it pull hard above 3k rpms? Or feel sluggish? I'd start with a check over of all the intake tubing, and vacuum lines to the boost sensor and wastegate, as well as make sure the wastegate opens / closes. Also you can remove (somewhat time consuming) the turbocharger boot at the front and inspect the impeller. Should spin freely with very little play, and the blades should be straight and smooth.
As for the spark plugs: NGK.
All specs are in the FSM: XenonZ31 Reference
and also check out:
ZBUM's New Nissan Z31 300ZX Homepage
Jason's Z Site - RedZ31.Com REDZ31.NET JASONBUTTS.COM
These sites have all basic and advanced questions answered in great detail
NismoPick is offline
Old 03-24-2015, 02:18 PM
Zuphoria's Avatar
Get a cheap 40$ mechanical boost gauge and use it as a tool to determine if you do in fact not have positive boost pressure. If you dont.... like nismo said... probely need to rebuild the turbo.
Zuphoria is offline
Old 03-24-2015, 03:45 PM
Grumpy & Helpful
rogerz's Avatar
I like Magnacore wires (check their website). but Bosch or NGK work. Zuphoria is right get a real gage but $40 for one is a little high. In the real world you buy what is called a compound pressure gage. when you tag on Boost the price doubles just like something labeled Marine. here is one on Amazon
WIKA 4255918 Commercial Pressure Gauge, Dry-Filled, Copper Alloy Wetted Parts, 4" Dial, 30"Hg-0-15 psi Range, +/-3/2/3% Accuracy, 1/4" Male NPT Connection, Bottom Mount: Industrial Pressure Gauges: Amazon.com: Industrial & Scientific WIKA 4255918 Commercial Pressure Gauge, Dry-Filled, Copper Alloy Wetted Parts, 4" Dial, 30"Hg-0-15 psi Range, +/-3/2/3% Accuracy, 1/4" Male NPT Connection, Bottom Mount: Industrial Pressure Gauges: Amazon.com: Industrial & Scientific
rogerz is offline
Old 03-24-2015, 10:57 PM
Not what I was hoping to hear but I figured that would be the worst case ill look into it more and get a real boost gauge. Am I doing any further damage to anything by driving it with a dead turbo if that's what it is? Thanks guys
Old 03-25-2015, 03:21 AM
zxguy1986's Avatar
No, you're just not getting the boost you expect. But first make sure the turbo isn't working. Friend of mine had his orig turbo totally rebuilt for about $300 so not a big deal. If you have to do that, good time to install a manual boost control so you can boost your torque higher than the factory-set +7 lbs to maybe +10, +11. (higher than that you will probably blow gaskets and seals.) Makes a diff you will notice - and cheap - and easy to install. You'll include a new (under-dash?) boost gauge - so that in-dash factory one won't matter much anymore. But it looks good there in the dash. Just leave it. Mother Nissan made it pretty. So leave it pretty.
zxguy1986 is offline
Old 03-26-2015, 09:07 AM
Zuphoria's Avatar
Why dont you post some pics? do you not know how?
Zuphoria is offline
Old 03-29-2015, 05:04 PM
Only two pictures I have of the car right now. Have not had the time to take a look at the car much going to next weekend. Was wondering what's a good brand or model boost controller to get?
Attached Thumbnails turbo issue new to 300zx-300zx-first-got.jpg   turbo issue new to 300zx-z.jpg
Old 03-29-2015, 06:47 PM
zxguy1986's Avatar
I put in this boost control combined with this gauge. There are a lot of choices out there.
Amazon.com: Voodoo IV Manual Turbo Boost Controller Anodize Blue Body Black ****: Automotive Amazon.com: Voodoo IV Manual Turbo Boost Controller Anodize Blue Body Black ****: Automotive
Amazon.com: GlowShift Tinted 7 Color 30 PSI Boost/Vacuum Gauge: Automotive Amazon.com: GlowShift Tinted 7 Color 30 PSI Boost/Vacuum Gauge: Automotive
Just found the diags we used - if that's any help.
Attached Thumbnails turbo issue new to 300zx-20130508095738_00001-diag1.jpg   turbo issue new to 300zx-20130508095718_00001-diag2.jpg
Old 03-29-2015, 10:47 PM
Planning on going with auto meter gauges but wasn't sure about a controller. Thanks zxguy1986 for the diagrams that helps out a lot since this is my first turbo car and know just about nothing about it yet.
Old 03-30-2015, 07:35 AM
Zuphoria's Avatar
Thats a nice looking 88T! you add her to the registry yet?
The Nissan Z and SX Registry
Zuphoria is offline
ZeeDeveel
10-07-2013 02:25 PM
strokergt
04-01-2013 11:54 AM
Bryan Cahanin
10-13-2012 08:34 PM
eishiba
10-10-2011 11:58 AM
bloodone
08-25-2005 09:22 PM
Quick Reply: turbo issue new to 300zx
