Oil Cooler and Synthetic oil questions
Old Dec 25, 2010 | 07:38 PM
TeamRonin's Avatar
Have a few questions on adding an oil cooler for my 88T. One, Im runnin pretty hot on my oil temperature roughly 280 degrees. Two, i just rebuilt my heads and was wondering if using Royal Purple XPR10W40 oil was okay for initial break in, along with RYP 80-90 in manual transmission and LSD? (Tranny n CLSD minor work done to them, not rebuilt yet) Since i rebuilt my heads ive noticed ive restored a lot of lost power but now heating up. Currently im using Castrol High Mileage 10w40.
-Is there a good oil cooler on the market to use or has noticable results? (Thinkin on a Hayden or Flexlite)
-Where is a great location to install it? ( Was thinkin, in the wheel well, like the automatic 88T has it or where i want is in between the intercooler and radiator)
PS
Will post pics soon of my work from majority of these write ups.
Old Dec 25, 2010 | 11:51 PM
I would test the resistance on the oil temp gauge and wiring, before jumping to conclusions. I doubt you are seeing anything more then 220* on the street.
Old Dec 26, 2010 | 01:00 AM
TeamRonin's Avatar
i did do that and it checked out alright. it also lead to my heater core blowing up. i been thinkin maybe something clogged or heater valve probs. wont know til tomorrow morning.
Old Dec 26, 2010 | 02:06 AM
Flacster's Avatar
http://www.redz31.net/pages/oilcooler.html oil cooler stuff
Old Dec 26, 2010 | 06:47 PM
Hitman Z's Avatar
Originally Posted by flacster
+++++1
Old Dec 27, 2010 | 07:17 PM
Checked out alright? As in it's 220 degrees or 280 degrees?
I have the same prob on my 280ZXT... the oil temp gauge reads close to 300* at running temp, but my infrared thermometer reads 205 at the side of the oil pan. I replaced my oil temp sensor, so next I'll be replacing my gauge pod.
Old Dec 27, 2010 | 08:15 PM
TeamRonin's Avatar
the guage checked out good and works properly. unfortunately i am unable to check it with infared due to my heater core explodin inside the cab and sprayin coolant all over the carpets. I do plan to check it again when i have everything put back together with an infared. Dawned on me right when ya mentioned about ya problem. I too believe my gauge is reading lower than what its suppose to. due to this later set back with HC it would have to wait to get a positive confirmation on the oil temp sensor and guage.
Old Dec 28, 2010 | 03:30 AM
tonsoffun300zx's Avatar
West Coast!
i installed the hayden medium duty cooler it was like $ 100 and the temp has stayed pretty much below 200 even on the freeways, but i installed it sandwiched between the a/c condenser and the little fan in the middle of the grille. well worth the investment i think good luck with the install.
Switchtr3
Mar 6, 2012 11:42 AM
KasbeKZ
May 24, 2010 08:21 AM
arsey51
May 11, 2009 03:50 PM
pearly whites
May 13, 2004 12:03 PM
Tuuurbo
Apr 27, 2004 04:33 PM
