Oil Cooler and Synthetic oil questions
Have a few questions on adding an oil cooler for my 88T. One, Im runnin pretty hot on my oil temperature roughly 280 degrees. Two, i just rebuilt my heads and was wondering if using Royal Purple XPR10W40 oil was okay for initial break in, along with RYP 80-90 in manual transmission and LSD? (Tranny n CLSD minor work done to them, not rebuilt yet) Since i rebuilt my heads ive noticed ive restored a lot of lost power but now heating up. Currently im using Castrol High Mileage 10w40.
-Is there a good oil cooler on the market to use or has noticable results? (Thinkin on a Hayden or Flexlite)
-Where is a great location to install it? ( Was thinkin, in the wheel well, like the automatic 88T has it or where i want is in between the intercooler and radiator)
PS
Will post pics soon of my work from majority of these write ups.
PS
http://www.redz31.net/pages/oilcooler.html oil cooler stuff
Checked out alright? As in it's 220 degrees or 280 degrees?
I have the same prob on my 280ZXT... the oil temp gauge reads close to 300* at running temp, but my infrared thermometer reads 205 at the side of the oil pan.
I replaced my oil temp sensor, so next I'll be replacing my gauge pod.
i installed the hayden medium duty cooler it was like $ 100 and the temp has stayed pretty much below 200 even on the freeways, but i installed it sandwiched between the a/c condenser and the little fan in the middle of the grille. well worth the investment i think good luck with the install.
