OBD1 Check Engine Light Diagnositic
Old 05-16-2017, 09:02 PM
Robin Hood's Avatar
Thumbs up OBD1 Check Engine Light Diagnositic
Hello, I have quick question about my OBD.
I was wondering how I would get the codes to be read from the Check Engine light instead of reading them from the OBD console. I once tried to check it but it didn't seem like any readable codes came up.
Let me know how it's done or if it's even possible!
Thanks guys.
Robin Hood is offline
Old 05-16-2017, 09:20 PM
Huh wha?
Click: XenonZcar.com Z31 ECU Diagnostics
Also click: Z31 Factory Service Manuals
NismoPick is offline
Old 05-16-2017, 09:32 PM
Robin Hood's Avatar
I see people shorting something out with Z's and they're able to read the codes from the flashing Check Engine light.
Old 05-17-2017, 10:33 AM
Did you click those links? And where are you seeing all these people "shorting something out" ?
Old 05-19-2017, 05:59 AM
86tcoupe's Avatar
Thanks guys.
it is reading the the blinking lights codes ,then looking that sequence up in the FSM.
to see data from the systems dealers had/have a break out box , which you need to see to help diag.
the climate control and cruise control use the a dash lite as code for there problems if I am remembering right
86tcoupe is offline
Old 05-19-2017, 04:22 PM
Grumpy & Helpful
rogerz's Avatar
the only way to get the codes is to follow the directions in the fsm. no way to read them just count the blinking lights (not a euphemism it is what they do.)
you would do better to put a cogent post on this forum as to your problem and you will probably get some answers.
rogerz is offline
Dirt Winston
03-26-2013 08:26 AM
joel280zt
08-02-2012 06:10 AM
Dgk910
11-09-2010 07:33 PM
bahumit12
01-15-2009 03:42 PM
speedracer1
11-18-2002 09:50 PM
Quick Reply: OBD1 Check Engine Light Diagnositic
