'88 300zx Heat/AC issues
Old Sep 27, 2011 | 08:06 AM
gstric44's Avatar
Hi, I'm new here so please any help would be appreciated. I have a strange problem here. When car is idleing and A/C is on it blows cold air fine thru the dash vents. When accelerating it then starts blowing heat thru the defroster and dash vents. Then when I come to a stop light it will return to blowing cold thru the dash vents. I have changed all the vacuum lines I coud find in the engine compartment but not the ones going thru the firewall. Any Ideas????
Old Sep 27, 2011 | 08:20 AM
mrbillishome's Avatar
Try replacing the carbon canister mounted on the core support behind the pass side headlight.
Old Sep 27, 2011 | 08:59 AM
Last time I checked, the carbon canister is for emissions control, not vent control.
I think you meant the vacuum tank?
Old Sep 27, 2011 | 10:41 AM
gstric44's Avatar
So do you think the vacuum tank could be causing my issue? I have replaced all the hoses going to it and still have the same problem.
Old Sep 27, 2011 | 11:54 AM
rogerz's Avatar
Grumpy & Helpful
you didn't note whether it is n/a or turbo makes a difference.
Old Sep 27, 2011 | 09:54 PM
gstric44's Avatar
It is Non-Turbo
Old Sep 29, 2011 | 10:13 PM
You sir are correct ha ha. I had just woken up that day.
Old Oct 3, 2011 | 11:13 AM
dboygardzina's Avatar
somewhat related.... my 86 non-turbo has a strong gas odor everytime I turn on the heat, any ideas?
Old Oct 4, 2011 | 06:05 AM
reddzx's Avatar
It's probably leaking fuel injectors and a fire waiting to happen. STOP driving it, and fix it before it burns up the entire engine compartment.
Old Oct 4, 2011 | 11:16 AM
I was reading a post somewhere in here about a recall on fuel injectors. I have an 86' non turbo, would I be able to get a freeby?
Old Oct 5, 2011 | 04:57 AM
reddzx's Avatar
You can try. Many dealers refuse to do it but if you are persistant, you may be able to find a dealer that will still do it.
Old Oct 5, 2011 | 05:16 AM
DuG's Avatar
DuG
Oh yes! this is a french joke to put a cheese near the air filter
norrie300
Sep 5, 2013 06:22 PM
Evan Faris
Feb 6, 2013 04:00 AM
cesar280z
Oct 28, 2012 05:33 PM
dboygardzina
Sep 14, 2011 06:54 PM
Plathore
Jun 22, 2008 05:52 PM
