'86 NA 2+2 idle
Old Aug 12, 2011 | 05:52 AM
EZee's Avatar
'86 NA 2+2 idle
Car idles rough with a noticeable miss when cold. Once it's warmed up, it idles very smoothly, but the idle speed seems to wander (as high as 1100 or as low as 600). I did a tune up (NGK plugs, Nissan wires, cap, rotor, air & fuel filter) and adjusted the TPS. No change. I messed with the idle speed screw and it didn't seem to have any affect, so I put it back where it was. Only codes were 31 & 23, which I believe are normal.
Edit: I just double checked, and I think I was turning the wrong screw for idle speed (left). So the info about having no effect is probably incorrect.
Old Oct 5, 2011 | 04:08 PM
Z31Turboed's Avatar
My '85 Turbo was hard to start, smelled rich and ran poorly until warmed up AND got poor mileage UNTIL I found a loose MAF conection after the MAF. Fixed that and it's been doing much better.
Check for leaks. Cracks in boots can be hidden on the other side.
madkiwi
Jun 6, 2015 07:40 AM
originalzboy
Feb 8, 2014 09:46 AM
kiboy6
Dec 13, 2008 01:53 AM
cartune77
Jan 28, 2005 11:21 AM
CL1
Aug 25, 2002 02:39 PM
