86 and 88 interchangeability
Old 03-08-2007, 12:12 AM
TRGBassGuy's Avatar
Hello to all of my fellow Z friends! I know someone who has a 86 2+2 manual and it is def a parts car. Now I have an 88 coupe. Real simple question here. Is all the glass interchangeable (I know the rear side windows aren't mainly pass. side door and windshield)? Also what I have is an auto (bleh) and the new one is a manual (hoorah!). I should be able to do the manual swap from all that right?
Sorry my mind is racing (pure excitement).
Thanks ahead of time!
TRGBassGuy is offline
Old 03-08-2007, 08:59 AM
No. Only the windshield is the same.
2+2 doors are longer and the hatch glass is shorter.
You may need a coupe 5-spd driveshaft for your conversion. I have that piece plus I have a couple rear hatch and corner windows. (all for sale)
Bleach is offline
Old 03-08-2007, 11:25 AM
TRGBassGuy's Avatar
How much for the driveshaft? The window I need is the pass side door. Previous owner scratched the glass pretty bad.
Old 03-08-2007, 01:15 PM
AZ-ZBum's Avatar
Driveshaft price could be anywhere from $5 to $500 depending on your source.
AZ-ZBum is offline
Old 03-08-2007, 03:19 PM
I was thinking $30
Bleach is offline
Old 03-08-2007, 07:44 PM
AZ-ZBum's Avatar
is it for an 87-89 NA 2 seater?
AZ-ZBum is offline
Old 03-08-2007, 09:42 PM
TRGBassGuy's Avatar
Yes it is. The 86 is a Turbo and I was thinking (and don't see why not when I have it right there) of dropping the turbo into mine (88). So right now it is an NA...I really don't see why I shouldn't make it a turbo.
Originally Posted by Bleach
I was thinking $30
Are you saying you have one for that price?
Old 03-08-2007, 10:22 PM
i have one from a 87 NA 2 seater 5spd for $40 +shipping..
hoov100 is offline
Old 03-08-2007, 11:02 PM
Yes the one I have for sale is from an 87 NA 2-seater 5-speed car. I sent you a private message about it.
...so you found a 1986 2+2 turbo car? if that car with the 5-speed is also a turbo car and has the T5 for the turbo engine then that changes everything. Please describe the cars better. The 2+2 300ZX did not come available with a factory turbo so if it truely is a turbo then the transmission could be either from the NA or turbo or maybe its an NA engine with a hokey turbo bolted on. Send pics. The BUM will know what it is.
Bleach is offline
Old 03-09-2007, 03:03 AM
TRGBassGuy's Avatar
You asked for them so here they are.
Now when I saw it at first I looked under the hood and saw what all of you see...the 3000. What actually tipped me off was the spoiler. Then as you see in the second picture it is a 2+2 and the front seats are (well, at least out of) a turbo. Now to me, when you look back at the engine that looks like a stock turbo.
However, I don't know for sure...which is why I have you guys (and gals).
Old 03-09-2007, 06:52 AM
AZ-ZBum's Avatar
You should look more closely at the engine. First, the 3000 plate doesn't say turbo. Second, the pipe right before the throttle body is plastic and is NOT connected to any turbo. And if you look more closely, you'll not find any turbo anywhere in the engine bay. And that's because the engine isn't a turbo. Also the injector cooling fan that's on the right side of the engine only came on the 86NA models in that location. And finally, the 15" NA wheels.
All 86 models came with a rear spoiler (in the US anyway) because of the third brake light that was added. The seats, are you sure those say turbo? I believe they say 300 across the top and ZX below. But it's hard to tell from the pictures. Regardless, that is not a turbo car, and that is not a turbo engine.
AZ-ZBum is offline
Old 03-09-2007, 12:27 PM
TRGBassGuy's Avatar
Then what is that right below the distributer cap? (curious now)
Old 03-09-2007, 12:52 PM
Below the distributor cap is the engine. In front of it (red) is the timing belt cover. Next to it (yellow) is your air conditioning pump. Did you think the AC compressor was a supercharger?
Bleach is offline
Old 03-09-2007, 09:00 PM
TRGBassGuy's Avatar
Ok, I thought the timing belt cover was covering the turbo. I have never seen that on an engine...of course I have only worked on the 88's. I knew what the air conditioning pump was (and wasn't).
Thanks Bleach and Bum....sometimes I am just oblivious.
bataradena
12-23-2017 07:08 AM
rogerz
09-28-2011 11:27 AM
Ratfink
03-12-2008 04:54 PM
struka
11-26-2006 09:33 AM
Quick Reply: 86 and 88 interchangeability
