Poly bushings..need opinions
Old 11-04-2011, 08:00 PM
dtmpower's Avatar
Ive read that a lot of people have done the poly bushings but I was wondering do they start to sqeel and screech...I never had poly bushings on any of my cars and some people say they start to sound annoying after a while. Any truth to this?..its my DD so is it better to go with polyurethane bushings or OEM rubber bushings?..all my bushings are shot so I gotta replace them pretty soon. thanks in advance.
dtmpower is offline
Old 11-04-2011, 08:46 PM
Primer Grey FTW!
evandubya's Avatar
put the lube on them and no squeky!
evandubya is offline
Old 11-04-2011, 11:45 PM
dtmpower's Avatar
doesnt the lube get dried up after a while??
dtmpower is offline
Old 11-05-2011, 04:16 PM
Grumpy & Helpful
rogerz's Avatar
Hasn't in three years. silicon based not petroleum. if your bushings are shot and you would like to have a car that goes where you point it rather than wandering the road like a drunk pig then replace the outer tie rod ends and balljoints when you do the bushings. you will be amazed at the handling difference. Shocks a good idea also.
rogerz is offline
Old 12-10-2011, 05:37 PM
Out of every race car with poly and solid bushings I have ever ridden in, drove or worked on, I have never had them squeak. Lube is the key, install zirk fitting if you have to.
hoov100 is offline
Dassan80z
08-01-2012 06:06 AM
kd0
05-20-2012 11:21 PM
dankfrye@charte
12-09-2011 02:57 PM
Z_guy
10-22-2008 10:51 PM
Spot
10-09-2002 08:51 PM
Quick Reply: Poly bushings..need opinions
