1978 280Z Rear clunk after installing new poly bushings
Old Nov 30, 2011 | 06:04 PM
dankfrye@charte's Avatar
I've read all the comments about worn out parts causing the rear clunk but mine is just the opposite. I have a 1978 280Z that made no rear clunking noise what so ever with the old rubber bushings. I just replaced the mustache bar, inner control arm and sway bar bushings with energy suspension poly and now when getting on and off the clutch I get the clunking. I used lots of grease and I torqued all the bushings down to spec. When I dropped my diff down, I did notice a piece of thick rubber fell off the top of the diff ander the arrestor strap. I put it back in where I thought it should go. Is this a factory piece (it looks kind of like a piece of tire rubber) or did a previous owner put it there to eliminate the clunk in the first place? I now have a better handling car but also have the dreaded clunk!
Thanks,
Dan
Old Nov 30, 2011 | 08:33 PM
theramz's Avatar
I have a present for you...
Thanks,
Dan
Yeah, the po was using that as a bump stop. Your front diff mount is broken.
Old Dec 9, 2011 | 07:04 AM
the_journeyman's Avatar
Scroll down the the bottom. This should take care of that pesky bump ~
http://www.arizonazcar.com/diffmount.html
JM
Old Dec 9, 2011 | 02:57 PM
These are really nice! I'll put them on my wish list!
mbgnh1
Aug 14, 2012 01:43 PM
dtmpower
Dec 10, 2011 05:37 PM
Z_guy
Oct 22, 2008 10:51 PM
gfkeph
Apr 30, 2003 05:31 PM
Spot
Oct 9, 2002 08:51 PM
