My Z31 rear wheels are slanting out at bottom?
Old Mar 25, 2013 | 05:23 PM
Evan Faris's Avatar
Ok my 88' Z31's rear wheels are "cambering" out a little bit. The bottom of my wheels are slanting out and are eating the tread on the insides of the tires. What could cause this? Bad shocks, springs, or my stock cambridge needs adjusted? The thing is, I went to O'Reilly today and they only carry adjustable cambridge kits for the front and not the rear. What could cause this? I don't know what it would be, but I surely don't want to be buying tires left and right! Please help. Thanks!
Old Mar 25, 2013 | 05:56 PM
illsahi's Avatar
They have negative camber stock on the rear wheels
Old Mar 25, 2013 | 08:30 PM
rogerz's Avatar
Grumpy & Helpful
take a set of the adjusting bolts out of a junker and use them to adjust camber. have to weld some metal on to make them work.
Old Mar 26, 2013 | 04:43 AM
Evan Faris's Avatar
Well there's no tool in stock at the car stores to adjust the "rear" of the car. Also there's an older guy I talk to if I have any questions and he has 3 Z cars. These are his exact words. "A spring that holds the car body up the correct distance from the axle will straighten out the axle to be horizontal, thereby making the tire/wheel assy straight up and down." So overall I just need new springs. Correct?
Old Mar 26, 2013 | 08:31 AM
Click n read (from Google):
Print Page - Tips on correcting Z31 Rear camber
84 - 89 300ZX (Z31) Rear Camber Modification
z31.com | Suspension | Rear camber adjustment
Z31 Rear Camber Modification Write Up + Photo by 1artworkz
Rear Camber adjustment - Nissan : Datsun ZCar forum :Nissan Z Forum: 240Z to 370Z
Old Mar 26, 2013 | 03:45 PM
Evan Faris's Avatar
Ok NismoPick I read some of it.. Is there anyway it could be just springs?
Old Mar 26, 2013 | 04:29 PM
rogerz's Avatar
Grumpy & Helpful
no stop smoking that stuff it ain't so easy. your veteran may have had 3 z's but he has not a lot of knowledge of mechanics. my list 83 n/a, 81 T, 83 T, 85T, 86T twice, 96 TT and now a 350 nismo. but hey ignore all that stuff and change springs.
Old Mar 27, 2013 | 04:23 AM
Evan Faris's Avatar
How would I even fix the cambridge then? What do I use? Do I have to buy anything to fix it?
Old Mar 27, 2013 | 04:36 AM
Evan Faris's Avatar
Ok there is no adjusting to the stock rear camber I read NismoPick's first link. If it's cambered out, bushings, shocks, springs, bolts and my cb joints are all bad? So basically wtf do I do? Lol.. Just fix all that? So confused..
Evan Faris's Avatar
*Cv joints
Old Mar 27, 2013 | 05:58 AM
Take the car to a well known quality alignment specialist shop (preferably one that works on imports). They will tell you if anything is bent, loose, or otherwise in need of replacing. Normal alignments cost ~$60 - $80.
Old Mar 27, 2013 | 02:52 PM
Evan Faris's Avatar
Will do.. Thanks
Notny41
Jun 21, 2013 04:12 PM
Pearl White Z32
Aug 7, 2012 07:53 PM
pcaudell
Jul 16, 2009 06:50 AM
sticky280zx
18
Feb 22, 2008 01:43 PM
JCBCPA
Jan 28, 2006 05:34 PM
