Z31 CVs work on 280ZXT?
Old Aug 14, 2011 | 09:55 PM
Is there a replacement for the 81-83 280ZXT like a Z31 or S13? I think the Pathfinders are shorter? I need to replace a spindle for the 280ZXT project car. The bearings ate the spindle
Old Aug 14, 2011 | 11:26 PM
Actually I'm looking at the FSM - it's the axel shaft - are these the same for the turbo and non turbo? (eg CV vs universal?)
Old Aug 15, 2011 | 08:55 AM
Z31 axles are too long. All 82-83 ZX's use the same cv instead of the 79-81 half shaft.
Old Aug 15, 2011 | 10:14 AM
Actually the NA's (typically) don't have CVs in 82 and 83 - just the turbos. Just trying to figure out if the axel shaft that the disk/wheel mounts to and the bearing ride on is the same on the universal AND the CV and it's just the companion flange that is different....
Old Aug 15, 2011 | 10:27 AM
In the 1983 FSM RA-7 has a diagram of the universal style. I'm assuming the CV is uses the same components in the hub but the companion flange is different?
Old Aug 15, 2011 | 12:24 PM
PurePontiacKid's Avatar
i felld offa mai trike
yeah, everything inside the control arm is the same, it's literally only the companion flange that is different from universal-style cars to CV cars.
Old Aug 15, 2011 | 01:21 PM
JSM's Avatar
JSM
The 280zxt Stub axles are 24 spline like the 240z. 280z (75-78) were the strong 27 spline. Not sure why they went smaller w/the turbo cars.
I'm not sure what the NA ZX spline count are. You may want to hit a JY up, pull the companion flange off and count the splines. Most likely they are the same.
Old Aug 15, 2011 | 02:29 PM
Thanks PPK - I knew there was a reason we kept you around...
Old Aug 21, 2011 | 07:12 AM
hmmm interesting so the wheel side flange is the same, i just have to find te diff side stubs and go to the parts store and order a new cv shaft if i want cv's???? that sounds too easy for some reason, i have a billion of the u joint shaft style ones, but no cv stuff
Old Aug 21, 2011 | 09:48 PM
You need the companion flange as well.... and the CV joints/shafts and the correct outputs for your diffs..... it's just that easy ;P
Old Aug 22, 2011 | 09:08 AM
on CV equipped S130's and other early cars, there isn't a diff side stub, the CV actually goes into the diff.
JoeGasm
Mar 25, 2009 07:56 PM
skittle
15
Aug 28, 2008 02:10 PM
jjohart
Jul 14, 2006 05:27 AM
moelll
Other Cars
Feb 6, 2006 11:10 PM
Bryan Thompson
Apr 14, 2005 09:21 AM
