Before I'm off to work
Old Mar 17, 2009 | 05:20 PM
JoeGasm's Avatar
I hit under the glove compartment in my car today with my skateboard, and coolant dripped inside the car.
I'll update when I get back from work (not driving the Z), and check out where the leak came from. Any help with that little info would be appreciated.
Old Mar 17, 2009 | 05:34 PM
probably heater core leak
Old Mar 17, 2009 | 05:39 PM
280zx2by2's Avatar
Haterade by da gallon!
lol your in for a world of fun...
Old Mar 17, 2009 | 11:01 PM
JoeGasm's Avatar
Oh Jesus H Christ...
If it comes down to heater core problems, can anyone post a how-to, with a possible window of time on how long it should take? I need it for work/school so I hope it doesn't take too long...
Old Mar 18, 2009 | 07:24 AM
It's all in your trusty Haynes manual. Remove dash, remove center heater control box, tear into control box, install new core, reinstall everything back into the car. Should take only 5-8 hours for a first timer.
I suggest finding the real problem before jumping to conclusions. A more common problem is the water **** which controls the flow of coolant into the heater core. Those usually go bad and start to leak. That's a much easier fix.
Old Mar 18, 2009 | 08:44 AM
lilt304's Avatar
[QUOTE=NismoPick;253595]Should take only 5-8 hours for a first timer. QUOTE]
So sad but so true.
Old Mar 18, 2009 | 09:21 AM
if you dont need heat right now you can always bypass the heater core and just connect the two heater core lines together for now while you work on it, i forgot to mention that it usually is the water **** that leaks, but i thought that was more behind the heater controls close to the fire wall, so i didnt think it would build behind the glove box
Old Mar 18, 2009 | 06:28 PM
DatsunKid's Avatar
Get outta my way.
I believe I had the same problem.
I call this a quick fix
Old Mar 18, 2009 | 09:28 PM
sho_shane's Avatar
Just block it off and live with out heat. Be like me. lol
Old Mar 18, 2009 | 09:58 PM
BlueKitsune's Avatar
Intrawebz Wizard
Is that...a stick?
Old Mar 19, 2009 | 01:12 AM
JoeGasm's Avatar
Well I'm going to look it over with my friend tomorrow, and hopefully it's not a heater core issue. For now, I think I'll bypass it, since it's summer in sunny So Cal...
Old Mar 19, 2009 | 06:10 PM
DatsunKid's Avatar
Get outta my way.
Is that...a stick?
Yes it is a stick.
Old Mar 19, 2009 | 06:52 PM
sho_shane's Avatar
That is awesome. lol
Old Mar 24, 2009 | 12:03 AM
JoeGasm's Avatar
I took it to my Auto Tech class, but we ran out of time to really inspect anything. I did find the source though- Under the glove compartment area (bottom of the dash), I have a black plastic cover with some oval shaped holes. I slapped it and one of them dripped coolant. Thing is, my radiator is fine and my coolant reserve is full o.O
Old Mar 24, 2009 | 06:45 AM
What color is the liquid? You've never mentioned it (just want to be clear).
And are you talking about the floor heat ducting? That would make since... the coolant is leaking from the heater core, and running to the floor ducting.
Old Mar 24, 2009 | 03:35 PM
JoeGasm's Avatar
It's coolant- a wierd yellow-green oily liquid.
Old Mar 24, 2009 | 06:03 PM
280zx2by2's Avatar
how did it taste? last time i had a swig it was really sweet
for real though you probly want to get in there and get in there and either fix the leak or bypass it, theres alot of important wires under there, your cruise control box (if you have cc) all the wires to your dash, and your fuse box...
Old Mar 25, 2009 | 07:56 PM
JoeGasm's Avatar
I plan on calling my friend up tomorrow, he has lots of experience with 280ZX's (he's gone through 5 in the last 2 years o.O) and he could help. He never learns to not drift drunk though...
skittle
Jan 25, 2007 09:40 AM
81 Black L28E
Jul 31, 2005 03:15 PM
UltimateZ
Jul 1, 2005 11:40 AM
Bryan Thompson
Apr 14, 2005 09:21 AM
myxp
Feb 2, 2005 10:58 AM
