Starting issue, yes I searched
Old Feb 8, 2009 | 10:49 PM
pete8717's Avatar
Exclamation Starting issue, yes I searched
I searched to try to find the answer but didn't find it. Might be blind. Here's how it started. One day the car wouldn't start. I turn the key and the there is a click from around the ignition relay and the starter doesn't move. I replace the relay, no go. Replace the solenoid, no go. What do you guys think it could be? The starter is fairly new so it shouldn't be that. Might be. I'll take the starter into autozone to get it tested. Appreciate the help guys! Thanks.
Pete
Old Feb 9, 2009 | 06:34 AM
KasbeKZ's Avatar
Pr0n Addict
battery?
Old Feb 9, 2009 | 06:44 AM
JhnRX7's Avatar
Check and clean all your electrical connections between the battery and starter. Same thing happened to me. Both power and ground cables go directly from the battery to the starter. Make sure all of those connections are clean. Also make sure that the small wire that triggers the starter solenoid is clean and has a good connection.
Old Feb 9, 2009 | 06:53 AM
rtmorgan's Avatar
Obsessive Craigslist Disorder
like they said^^^ insufficient power to the starter
Old Feb 9, 2009 | 06:54 AM
rtmorgan's Avatar
if you drove something lighter you could do like i used to.
i push started my geo metro for 3 months in high school cause i was too poor to get a new starter lol
Old Feb 9, 2009 | 01:29 PM
pete8717's Avatar
I just bought the battery in October last year. I'll be pissed if it's that. I cleaned all of the connections and it's a no-go. Had the starter tested at auto zone and it was fine.
Old Feb 9, 2009 | 02:56 PM
oneadvent's Avatar
you could try pushing it, cause if the battery was totally shot pushing wouldn't work either.
Old Feb 9, 2009 | 04:30 PM
icice9's Avatar
Super Siver & Black Stud
it might be your ignition switch....try using a remote starter and connect it to the starter.. if it turns i doubt its your starter or your batt.. or if you dont have a remote starter you can use a screwdriver.. just jump the pos (+) connection on the starter to the yellow wire on the solenoid.
Old Feb 9, 2009 | 05:01 PM
i would check the battery, put a volt meter to if you have one, or jump it with another car and see if it works, might end up being the switch like ice said though, but the battery is easier to test, also the tests they do at autozone arent vary accurate, the best way to test a starter is to pull it out of the car, but leave it hooked up and have someone else bump the starter to see if it works period.
Old Feb 9, 2009 | 06:25 PM
280zx2by2's Avatar
Haterade by da gallon!
i respect you so much... you have no idea
lol there is so much fail in your statement that its honorable
Old Feb 9, 2009 | 06:35 PM
rtmorgan's Avatar
well what can i say i was a poor kid
Old Feb 9, 2009 | 06:36 PM
rtmorgan's Avatar
at least i had wheels and could fill up for like 12 bucks too lol with 91 oct.
Old Feb 10, 2009 | 04:10 AM
280zx2by2's Avatar
i want to fill up my z with 91 just to see what it does
Old Feb 14, 2009 | 02:44 PM
pete8717's Avatar
I got the car running but it's acting pretty funny. The voltometer is readin 17, 18 volts and it fluctuates, ouch big word, and when I hit the brakes or turn on some other electrical accessories everything fades and the needle drops real low. Do you guys think this is a grounding problem? That was the reason it wasn't running in the first place. Ground from starter to body was disconnected. There is some corrosion around there and It's an old cable anyways. This might be my problem but can't work on it till tuesday. Oh and I had the battery tested and it was fine.
I fill my Z up with 91 octane all of the time. It's all I use in it. It gets pretty peppy...
Old Feb 14, 2009 | 03:06 PM
^^^ Classic sign of a dying alternator.
Old Feb 14, 2009 | 04:14 PM
pete8717's Avatar
I have thought that as well but the alternator was changed in early 2006. The car sat from june '06 till october 2008. I don't think it's that.
Old Feb 14, 2009 | 04:22 PM
Is it a reman alternator? Many remanufactured alternators suck, and just because it's 3 years old, doesn't mean it's not going bad. There's not many other explanations for 17-18 volts....
Old Feb 16, 2009 | 07:30 AM
pete8717's Avatar
I got it brand new. I'm still leaning towards a grounding problem... I will find out on tuesday when I get to see my car again.
Old Feb 17, 2009 | 11:23 AM
Twitch's Avatar
i think i have a grounding problem too.I lost all spark one day when i was driving and have since than installed a blaster 2 coil,new plugs,and crane xr-700 ignition kit to replace the ignition module which i thought at first was the problem.It turns over no problem but it just spins with no fire.i have no clue what to do but i need my car running.rides to work every day suck.Also a week before it gave out sometimes the voltmeter in the dash would jump around from 10 to 15-16 voltsAny ideas?
________
Herbal vaporizer blend
1979 280z
Jan 5, 2015 02:58 PM
Unorthodox
Oct 11, 2013 11:15 AM
Lesnocker
Feb 11, 2011 01:13 PM
OpenRange
Aug 26, 2009 12:54 PM
280z racer
Sep 25, 2007 11:29 AM
