Passed Smog Today!!!!
Doesn't post much...
Yup, My car decided it wanted to live another two years today and actually passed smog on the first attempt.
For the first time since I have owned it, there were no signs that it's running too rich. Yay!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!
I guess all those shiney new parts and bloody knuckles were good for something.
Rod.
Rod.
Sweet. Good to hear she wasnt hacked up. Looks like we're all gettign **** done this weekend. I got both Z's to there new home for the swap and plan to get it crackin this week! Just a tip though . . .tow dollies SUCK. that is all Contgrats Rod.Shall we count you in for MSA now?
Originally Posted by lww
hehehe!! Congrats! I guess those new injectors finally got worked out? What else was causing it to run rich?
Had to be my AFM more than anything. With the new one in there, it burns right where it's supposed to. Of course, there were all the other new parts too like the CHTS and Air Reg and all that other crap, but a lot of those were new on the last test and it didn't burn nearly this good. AFM was the main culprit I'm sure.
It still idles a pretty rough, but me and the smog tech agree that it's most likely because of the exhaust. I have the 2.5 tubing and custom collector with an oversized 3 way cat and a very noisy muffler that now has about 40K on it... In other words... No back pressure.
Make sense to you L-dub? I'm curious as to your thoughts on that.
Yeah, Me AND my car will be at MSA this year!
Rod.
Originally Posted by RodMoyes
it still idles a pretty rough, but me and the smog tech agree that it's most likely because of the exhaust. I have the 2.5 tubing and custom collector with an oversized 3 way cat and a very noisy muffler that now has about 40K on it... In other words... No back pressure.
It's certainly a possibility. When you say it idles pretty rough, is it surging or just a random stutter?
No surging at all. However, it does seem like I can never really "Set" the idle. It changes +/- 150 RPM's depending on how long the car has been running. Throttle body may be a little sticky though.
Rod.
Originally Posted by apollo
Dont all Z's stutter? I dont think ive come across an S130 that has had an original motor that didnt stutter despite the fact they ran like a champ.
It's almost the same stutter you would have if you had a high duration cam... It lopes more than stutters I guess... Like an SBC with a big cam.
Rod.
Well ****. Cant you be happy for now, damnit? It passed smog, runs fine and has a lil stutter. Think of it as character . . . .
I'm not complaining... It's ALL good! Rod.
Surging is usually the symptom for a too low back pressure. But a loping could be considered a surge too so your exhaust is still a possibility in my opinion.
What kind of coil and ignition wires are you using? When's the last time you gapped your plugs?
Most idle issues I've dealt with have been from ignition/spark problems.
After all the stuff you replaced trying to get it smogged, i can't think of anything else that you haven't already checked!
Yeah, but I know of plenty that idle smoother than mine does.
Rod.
Rod.
psh... smog.... emmisions... anything 94 and older in IL now nolonger has to do **** but be registered and insured to drive on the roads.... its to pricey to do the dyno emmessions runs compared to plugging in a computer to the OBII cars...
I'm sticking with the back pressure theory...
Rod.
Hey Rod, sorry for the late props. But great job bro', I had faith in you. And considering you passed Cali smog, which is harder than AZ smog. That means your Z, runs leaner than mine. Well I will figure out why mine is. I think I need to clean the o2 sensor, and check the timing again.
Anyway glad to hear it all worked out for you.
Thanks WildmaN,
Now all I have to do is pull all the glass, remove the interior, have all the dents removed, the whole car repainted (again) and re-do the interior before late April and I'm all set!!!
I'm now a big believer in replacing the AFM. It was the one thing that made the most difference.
Cleaning and adjusting your old one only does so much... I did all that and got some results but never enough to really bring it back to what it was supposed to be.
If you're still running too rich, I would seriously think about replacing that bad dog.
Rod.
Rod.
the AFM might have been the problem on my NA engine. It passed at cruise and got me great gas milage but ran too rich at idle. oh well, that engine is long gone.
Now if only my Pulsar will pass. I'll be working on that car on Thursday and take it in again Fri or Saturday.
Queen of Yachts
rod--have you driven the car 30 minutes minimum after the change outs????
mine all went away by themselves------mebbe yers will, too?............and congrats on smog passing-------it is not difficult if car is right........!!!!(mine arenot always right).......
, well then. . .as long as you aint complaining and its cool. Toyt
