Ok Big Problem!
Old Sep 23, 2005 | 07:00 PM
ThermalWake's Avatar
Ok Big Problem!
Ok I Was Having Injector Problems On The 6th Injector.. We Just Replaced It With A New One, And Its Not Working. The Plugs Are Good. We Swapped 5th And 6th Plugs, And Plug Wires Plugs And Wires Are Good. We Swapped Injector Wires. The 6th Wire Makes The 5th One Work, But The 6th One Doesent Make The 6th One Work Neither Does The 5th Wire Make The 6th Injector Work, But The 6th Wire Makes The 5th Injector Work As Well Does The 5th Wire Make The 5th Injector Work... Wat Are The Chances Of Brand New Injector Being Faulty, I Need To Know Asap I Need A Vehicle Asap
Old Sep 23, 2005 | 07:06 PM
jfairladyz's Avatar
It's possible. Especially since it's a rebuilt one. I thought I remembered you saying it's a rebuilt one. A lot of rebuilt parts are just cleaned up parts if there isn't any damage to them and they are still within specs. So take it back and try another one. Explain to them that you checked and verified it was the injector.
Old Sep 23, 2005 | 07:07 PM
no we got a brand new one instead.
Old Sep 23, 2005 | 07:15 PM
FubarI33t's Avatar
wireing maby?
Old Sep 23, 2005 | 07:19 PM
no its not wiring because we swapped wiring on the 5th and 6th injectors. they both make the 5th one work but neither 5th or 6th wires make the 6th one work
Old Sep 23, 2005 | 07:21 PM
jfairladyz's Avatar
It could still be faulty. **** happens. It really, really, really sounds like you eliminated everything but the infector.
Alright so let me get this straight.
#6 wires fires number #5.
#5 wires fires #5.
#6 wires does not fire #6.
#5 wires does not fire #6.
Does that sound right? If that's the case then I don't see what it could be other than the FI.
Old Sep 23, 2005 | 07:23 PM
FubarI33t's Avatar
sounds like FI then.
Old Sep 23, 2005 | 07:24 PM
jfairladyz's Avatar
Ok disregard the part about the wiring then, you just answered that while I was typing It's gotta be the injector then. Nothing else it could be that I can think of. Are you sure it's not firing? Are you sure it's getting fuel? Is the line to the injector being pressurized with fuel? If you're sure it's not firing then I guess it wouldn't really matter if it's getting fuel though.
Old Sep 23, 2005 | 07:26 PM
jfairladyz's Avatar
Just to satisfy all curiosity here. Have you tried swapping the infectors around? Try that. Put the new injector in the #5 spot and see if it fires. If it still doesn't fire than it HAS to be the injector.
Myzsucksass
Nov 28, 2013 06:58 AM
turbo84z
Oct 10, 2006 07:30 AM
HybridS130
Sep 2, 2006 05:50 PM
pearly whites
Oct 30, 2003 01:37 PM
saaddaa7
Oct 24, 2003 08:19 PM
