Need to replace Heater Core!!
Old Dec 28, 2010 | 06:31 PM
NewZx's Avatar
Ok, Im new to the 1983 280zx. I bought this car a few days ago, and the guy who sold it to me said the heating core leaked in the car. The heat doesnt work in the car, and I dont know how to replace the heating core. Do I need to take out the entire dash, or can i take out the Glove Box and get to it??
Old Dec 28, 2010 | 06:49 PM
www.xenons130.com
Old Dec 28, 2010 | 07:11 PM
NewZx's Avatar
It doesnt say if i need to take the whole dash out or not.
Old Dec 28, 2010 | 07:16 PM
NewZx's Avatar
Since there is a leak, is it most likely the heater core or something else?
Old Dec 28, 2010 | 07:19 PM
BlueKitsune's Avatar
Intrawebz Wizard
I just changed mine out and I don't seen how you can do with w/o taking the entire dash out. I ended up removing my entire dash and the crossbar under the dash. when I first did this tho I forgot about the 2 bolts holding the A/C controls to the dash tho.
Old Dec 28, 2010 | 07:28 PM
NewZx's Avatar
I know the glove box will come out, and i wasnt sure if i could get to it though there.
Old Dec 28, 2010 | 07:31 PM
attacksoma's Avatar
If you need to change the hoses from the engine to the heater core then you can only take the glove box, and the panel below it . But If you need to replace the whole heater unit , then just take the dash out.. Its actually very simple ( plus you will have some working room)
Old Dec 28, 2010 | 07:35 PM
NewZx's Avatar
Alright, I just dont want to get it apart and not know what im doing. I've never worked on a zx before.
Old Dec 28, 2010 | 07:45 PM
NewZx's Avatar
@bluekitsune, how long did it take you to get the dash out and a new core in and put back together??
Old Dec 28, 2010 | 08:50 PM
zordietrying's Avatar
I just replaced me heater core and my heater valve in my 82 280zxt. And I did it with out taking out the dash. It wasn't that hard and didn't take that much time. A few years ago i tried to pull the dash out. It took way to long and to much work, so I gave up. Some people say its easy but I don't see how, i wish they would show me or do a write up so I could do it that easy.
Old Dec 28, 2010 | 08:55 PM
NewZx's Avatar
Alright, thanks. Did your heater core leak also? And I'm guessing that you just went thought the glove box?
Old Dec 28, 2010 | 09:56 PM
Oh hai... dash removal: https://www.zdriver.com/forums/280zx-s130-forums-77/remove-dashboard-25586/
Dash removal process:
-Remove steering wheel (18mm nut?)
-Remove knee kick panels
-Remove entire radio unit
-Remove all 10mm bolts at mid level
-Remove vent control border & then you will see 2 more screws)
-Remove phillips screws at windshield
-Disconnect wiring harnesses @ passenger door A-pillar
-Pull dash out several inches
-Get under drivers side dash, reach up to speedo cable, & twist off.
Out comes dash.
Old Dec 28, 2010 | 11:13 PM
ZguyECV's Avatar
Exactly its cake takes a whole what 10-15 min top. Give urself the room itll cause you a whole lot less frustration.
Old Dec 28, 2010 | 11:47 PM
Intrawebz Wizard
I've removed that unit and dash once before so it only too me around 3 hours or so to changed out everything and have it all hooked up. But if you haven't done it before I'd give yourself the better part of the day if not a weekend just to be on the safe side.
Old Dec 29, 2010 | 07:32 AM
NewZx's Avatar
Alright, thanks everyone. Still deciding if I want to do this or just brave the cold. Thanks guys. Is getting the dash out the hardest part, or is it changing the heating core??
Old Dec 29, 2010 | 07:45 AM
280zx2by2's Avatar
Haterade by da gallon!
My heater core busted 2 weeks ago... The day after a 500 mile trip with the heater blasting the entire way haha.
Not looking forward to doing this....
Old Dec 29, 2010 | 09:07 AM
lifegrddude's Avatar
Externally Wastegated
The dash is about an hour job if you haven't done it before and you take your time. Finding the necessary bolts/screws to remove is what is a pain. It does help if you have a friend to help you lift out the dash from the car since most of the dashboards I've seen are brittle from age. It took me 3 days to change out my old heater core, swap from auto to manual a/c and change out all the vacuum lines under the dash.
I figure if you're just doing a heater core, it'd take you half a day on your first try. It'd be a good idea to change the heater control valve and heater hoses while you're at it so you don't have to repeat the process again for a while.
Old Dec 29, 2010 | 02:41 PM
NewZx's Avatar
Alrite thanks. I might just suffer tho. Sounds like it will take longer than I thought.
DKNYbaseball
Aug 10, 2016 02:32 PM
plainwhiteZ
Feb 20, 2009 02:33 PM
SysqoeZ32
Mar 8, 2007 01:25 PM
zfanman
Jun 21, 2005 10:16 AM
coop1
Apr 25, 2003 11:33 AM
