Need to replace Heater Core!!
Ok, Im new to the 1983 280zx. I bought this car a few days ago, and the guy who sold it to me said the heating core leaked in the car. The heat doesnt work in the car, and I dont know how to replace the heating core. Do I need to take out the entire dash, or can i take out the Glove Box and get to it??
It doesnt say if i need to take the whole dash out or not.
Since there is a leak, is it most likely the heater core or something else?
I just changed mine out and I don't seen how you can do with w/o taking the entire dash out. I ended up removing my entire dash and the crossbar under the dash. when I first did this tho I forgot about the 2 bolts holding the A/C controls to the dash tho.
I know the glove box will come out, and i wasnt sure if i could get to it though there.
Originally Posted by NewZx
(Post 288930)
Alright, I just dont want to get it apart and not know what im doing. I've never worked on a zx before.
@bluekitsune, how long did it take you to get the dash out and a new core in and put back together??
I just replaced me heater core and my heater valve in my 82 280zxt. And I did it with out taking out the dash. It wasn't that hard and didn't take that much time. A few years ago i tried to pull the dash out. It took way to long and to much work, so I gave up. Some people say its easy but I don't see how, i wish they would show me or do a write up so I could do it that easy.
Alright, thanks. Did your heater core leak also? And I'm guessing that you just went thought the glove box?
Oh hai... dash removal: :D https://www.zdriver.com/forums/280zx-s130-forums-77/remove-dashboard-25586/
(Post 223335)
Dash removal process:
-Remove steering wheel (18mm nut?) -Remove knee kick panels -Remove entire radio unit -Remove all 10mm bolts at mid level -Remove vent control border & then you will see 2 more screws) -Remove phillips screws at windshield -Disconnect wiring harnesses @ passenger door A-pillar -Pull dash out several inches -Get under drivers side dash, reach up to speedo cable, & twist off. Out comes dash. |
Exactly its cake takes a whole what 10-15 min top. Give urself the room itll cause you a whole lot less frustration.
(Post 288936)
Alright, thanks everyone. Still deciding if I want to do this or just brave the cold. Thanks guys. Is getting the dash out the hardest part, or is it changing the heating core??
My heater core busted 2 weeks ago... The day after a 500 mile trip with the heater blasting the entire way haha.
Not looking forward to doing this.... |
The dash is about an hour job if you haven't done it before and you take your time. Finding the necessary bolts/screws to remove is what is a pain. It does help if you have a friend to help you lift out the dash from the car since most of the dashboards I've seen are brittle from age. It took me 3 days to change out my old heater core, swap from auto to manual a/c and change out all the vacuum lines under the dash.
I figure if you're just doing a heater core, it'd take you half a day on your first try. It'd be a good idea to change the heater control valve and heater hoses while you're at it so you don't have to repeat the process again for a while. |
Alrite thanks. I might just suffer tho. Sounds like it will take longer than I thought.
