Need advice maybe with suspension/front end issue
Old Feb 6, 2011 | 08:16 PM
jginther1981's Avatar
Hey all, I'm new to Z cars. Just bought an 81 280zx today. I've noticed however the steering wheel vibrates pretty badly when I need to turn, and there is a lot of play in it. Also the front end sometimes makes a popping sound when I turn the wheels. Anyone know what part of the front end this could be? Any help for this newbie would greatly appreciated.
Thanks
Old Feb 6, 2011 | 08:27 PM
mrprofile's Avatar
well, my sisters honda civic from the 80's steering wheel shakes when it idles, and we know it's the motor mounts causing that, maybe you could be having the same problem.
Old Feb 6, 2011 | 08:28 PM
Welcome to ZDriver!
Most likely ball joints or tension rods... hop under there and take a look. The front suspension is pretty simple.
Old Feb 6, 2011 | 08:30 PM
do you know another name for the tension rods? i'm looking on parts house sites and cannot find anything in their search engines for "tension rods"
Old Feb 6, 2011 | 08:33 PM
http://nissan4u.com/parts/280zx/us_s...llustration_3/
#34: Rod tension
Here is the other ill just in case you need it...
http://nissan4u.com/parts/280zx/us_s...llustration_1/
Old Feb 6, 2011 | 09:17 PM
noboosts130's Avatar
Lurker
It could also be a bad idler arm. Mines an '80 and it shakes at 40mph.
Old Feb 6, 2011 | 10:05 PM
rogerz's Avatar
Grumpy & Helpful
you should probably replace the outer tie rod ends, ball joints and put in a set of poly bushings. that will probably cure it unless you see something that is obviously broken. but doing that anyway if you are keeping the car will make your driving easier. Is there power steering fluid in the reservoir.
Old Feb 7, 2011 | 07:33 AM
oh the other thing is it only shakes when i turn.....not necessarily when i'm getting up to speed.
Ehsan Abbassi
Sep 27, 2012 12:48 PM
trailerbred
May 7, 2012 07:06 AM
thefire80
Sep 20, 2010 11:38 AM
94porkchop
Sep 14, 2010 09:18 PM
'76Z
Mar 20, 2004 02:10 PM
