Need advice maybe with suspension/front end issue
Hey all, I'm new to Z cars. Just bought an 81 280zx today. I've noticed however the steering wheel vibrates pretty badly when I need to turn, and there is a lot of play in it. Also the front end sometimes makes a popping sound when I turn the wheels. Anyone know what part of the front end this could be? Any help for this newbie would greatly appreciated.
Thanks
Thanks
http://nissan4u.com/parts/280zx/us_s...llustration_3/
#34: Rod tension
Here is the other ill just in case you need it...
http://nissan4u.com/parts/280zx/us_s...llustration_1/
#34: Rod tension
you should probably replace the outer tie rod ends, ball joints and put in a set of poly bushings. that will probably cure it unless you see something that is obviously broken. but doing that anyway if you are keeping the car will make your driving easier. Is there power steering fluid in the reservoir.
Ehsan Abbassi
Sep 27, 2012 12:48 PM
trailerbred
May 7, 2012 07:06 AM
94porkchop
Sep 14, 2010 09:18 PM
