My seat broke!
Old Apr 9, 2012 | 08:48 AM
Pipsqueak's Avatar
My seat broke!
I need some advice.
I have a 80 280 zx coupe
The drivers seat broke yesterday. The part that allows the seat to lean back will not hold. the seat is now stuck in the "reclined" position.
I don't think I can fix it, so I'm looking for a replacement.
I don't think i want to go with racing seats. this is my daily driver, and the racing seats I have seen just don't look comfortable. pulse I'm not the light weight I should be.
I have seen the write up on the acura seats by 83turbo280zx, but no luck on finding any in my area.
any other suggestions on replacement, are a place that might carry oem type seats.
Old Apr 9, 2012 | 09:34 AM
https://www.zdriver.com/forums/240z-280zxt-s30-s130-tech-tips-275/where-what-seats-can-i-get-my-z-19918/
https://www.zdriver.com/forums/240z-280zxt-s30-s130-tech-tips-275/honda-seat-install-280zx-17988/
Old Apr 9, 2012 | 12:10 PM
rogerz's Avatar
Grumpy & Helpful
I'd look at the seat mechanism. it is fairly simple as I remember and perhaps all you need is bending a tang back in place or a spot of welding. get a set of hogring pliers to put the upholstery back together.
Old Apr 12, 2012 | 07:50 AM
Pipsqueak's Avatar
had time to pull the seat last night.
I found a bolt that had snapped, I was able to remove it, now I just have to find a replacement. I hope this will fix my issues.
BUT...
Once the seat was out and apart, I found a wire running from the seat belt latch that was not plugged in. I assume it is for the seat belt warning light ( if the car has one), but I can not find anyplace to plug it in.
so now I'm question if I have the original seats, or is the plug I'm looking for not on the base mode.
Old Apr 12, 2012 | 11:02 AM
rogerz's Avatar
Grumpy & Helpful
I seem to remember an odd unused wire to the seat belt. if everything works why worry. You can buy bolts anywhere just get the size and thread or take what you have to a bolt place they can identify it. get grade eight higher ksi in shear than regular.
Brotha_Z
Jan 27, 2014 04:25 PM
DavidMulligan
Dec 17, 2012 12:25 PM
KasbeKZ
33
Nov 7, 2007 05:24 PM
thxone
May 24, 2006 12:09 PM
espi
Jan 31, 2006 06:11 PM
