Lubrication system school help
Old Jan 31, 2009 | 01:10 PM
dustin_ra's Avatar
Question Lubrication system school help
OKay so last week I started school at UTI in Avondale AZ. Well the courses I am taking are Automotive/ Diesel/ and plan on taking hydraulics and refrigerant to include the Industrial side.
Anywho. I am in class and using my Z specs on a worksheet. The problem is that the school uses some useless website. I also used their whatever to 81 oldschool Chiltons manual. I got most of what I was looking for except the info wasnt for and 81 but for 80.
I need the specs on the Lubrication System
1. Vehicle yr. 1981.
2. Vehicle Make Datsun/Nissan.
3. Vehicle Model 280Zx
4. Engine size CC/ or CU
5. Reqd Oil Weight ?
6. Reqd Oil Rating ?
7. Service Intervals:
Light Service ?
Heavy Service ?
8. Location of Oil Pressure Sending Unit ?
9. Oil Pump Type Rotor
10. Oil Pump Location: Located BTM of engine front cover
11.The Oil Pump is Driven by the: Camshaft?
12.OIL Pump Specifications:
13. Oil Pressure at Idle cold: HOT:
14. Oil Pressure at 2000 RPM Cold: HOT:
Old Jan 31, 2009 | 04:14 PM
Check in the Haynes or FSM.
Old Jan 31, 2009 | 06:29 PM
dustin_ra's Avatar
What is this FSM you speak of. If it is our zdriver search button, its not the info I have been looking for. Has plenty of specs like hp and tq but not lubrication info.
Old Jan 31, 2009 | 06:35 PM
You should buy a Haynes manual... has all the specs you are looking for on page 25-27.
FSM = Factory Service Manual. Can be downloaded here: www.xenons130.com
Old Jan 31, 2009 | 07:09 PM
dustin_ra's Avatar
I have one but after moving I am having issues locating it. I found my two other manuals for my pickup but as for the car manual I cannot find it.
Old Jan 31, 2009 | 07:14 PM
I have two... one for the garage, one for the house. Another $14 might be a wise investment for you.
Old Jan 31, 2009 | 07:23 PM
dustin_ra's Avatar
I will have to do that as seen I cannot locate mine. I have chosen to change the vehicle on the worksheet to my pickup. I only hope I can find everything I need.
I saw a built GM 355 at the school and I want it for my Z.
Old Jan 31, 2009 | 07:35 PM
Here's some quick answers for you, from www.google.com and the Haynes manual.
4. Engine size CC/ or CU: 2393cc
5. Reqd Oil Weight? As in all cases... it depends on the operating conditions.
6. Reqd Oil Rating? SAE
Light Service? @ 1000, 3750, 7500, 15000, 30000 miles.
Heavy Service? When needed.
8. Location of Oil Pressure Sending Unit? Passenger side of block, near motor mount.
9. Oil Pump Type: Rotor
11.The Oil Pump is Driven by the: Camshaft? No, crankshaft.
14. Oil Pressure at 2000 RPM Cold: HOT: I don't have exact #'s... but 60psi+ is normal when cold. 30-60psi when hot.
Old Jan 31, 2009 | 09:15 PM
dustin_ra's Avatar
For the oil weight I meant factory pref.
The reqd oil I was asking the oil letter code.
I think you meant API not SAE.
Thank you for the info you provided.
Old Jan 31, 2009 | 10:53 PM
pete8717's Avatar
Hate to correct you nismo but the engine cc is 2753cc. not 2393
Old Feb 1, 2009 | 06:55 AM
dustin_ra's Avatar
Maybe he has one of those special Zs
Old Feb 1, 2009 | 11:22 AM
Ah yeah... sorry I was looking at the L24 specs.
Old Feb 1, 2009 | 06:03 PM
dustin_ra's Avatar
Found my manual finally. Was in a travel suit case.
snwbrderphat540
Feb 18, 2008 08:50 AM
RodMoyes
Jul 16, 2007 03:48 PM
WichitaZRide
Jul 2, 2005 06:55 PM
calvinD
Aug 23, 2003 01:29 PM
RaCeRzX
Nov 3, 2002 09:11 PM
