Lubrication system school help
OKay so last week I started school at UTI in Avondale AZ. Well the courses I am taking are Automotive/ Diesel/ and plan on taking hydraulics and refrigerant to include the Industrial side.
Anywho. I am in class and using my Z specs on a worksheet. The problem is that the school uses some useless website. I also used their whatever to 81 oldschool Chiltons manual. I got most of what I was looking for except the info wasnt for and 81 but for 80. I need the specs on the Lubrication System 1. Vehicle yr. 1981. 2. Vehicle Make Datsun/Nissan. 3. Vehicle Model 280Zx 4. Engine size CC/ or CU 5. Reqd Oil Weight ? 6. Reqd Oil Rating ? 7. Service Intervals: Light Service ? Heavy Service ? 8. Location of Oil Pressure Sending Unit ? 9. Oil Pump Type Rotor 10. Oil Pump Location: Located BTM of engine front cover 11.The Oil Pump is Driven by the: Camshaft? 12.OIL Pump Specifications: 13. Oil Pressure at Idle cold: HOT: 14. Oil Pressure at 2000 RPM Cold: HOT: |
Check in the Haynes or FSM.
What is this FSM you speak of. If it is our zdriver search button, its not the info I have been looking for. Has plenty of specs like hp and tq but not lubrication info.
You should buy a Haynes manual... has all the specs you are looking for on page 25-27.
FSM = Factory Service Manual. Can be downloaded here: www.xenons130.com |
I have one but after moving I am having issues locating it. I found my two other manuals for my pickup but as for the car manual I cannot find it.
I have two... one for the garage, one for the house. Another $14 might be a wise investment for you.
I will have to do that as seen I cannot locate mine. I have chosen to change the vehicle on the worksheet to my pickup. I only hope I can find everything I need.
I saw a built GM 355 at the school and I want it for my Z. |
Here's some quick answers for you, from www.google.com and the Haynes manual.
4. Engine size CC/ or CU: 2393cc 5. Reqd Oil Weight? As in all cases... it depends on the operating conditions. 6. Reqd Oil Rating? SAE 7. Service Intervals: Light Service? @ 1000, 3750, 7500, 15000, 30000 miles. Heavy Service? When needed. 8. Location of Oil Pressure Sending Unit? Passenger side of block, near motor mount. 9. Oil Pump Type: Rotor 10. Oil Pump Location: Located BTM of engine front cover 11.The Oil Pump is Driven by the: Camshaft? No, crankshaft. 12.OIL Pump Specifications: 13. Oil Pressure at Idle cold: HOT: 14. Oil Pressure at 2000 RPM Cold: HOT: I don't have exact #'s... but 60psi+ is normal when cold. 30-60psi when hot. |
For the oil weight I meant factory pref.
The reqd oil I was asking the oil letter code. I think you meant API not SAE. Thank you for the info you provided. |
Maybe he has one of those special Zs
Ah yeah... sorry I was looking at the L24 specs. :D
Found my manual finally. Was in a travel suit case.
