Lubrication system school help
OKay so last week I started school at UTI in Avondale AZ. Well the courses I am taking are Automotive/ Diesel/ and plan on taking hydraulics and refrigerant to include the Industrial side.
Anywho. I am in class and using my Z specs on a worksheet. The problem is that the school uses some useless website. I also used their whatever to 81 oldschool Chiltons manual. I got most of what I was looking for except the info wasnt for and 81 but for 80.
I need the specs on the Lubrication System
1. Vehicle yr. 1981.
2. Vehicle Make Datsun/Nissan.
3. Vehicle Model 280Zx
4. Engine size CC/ or CU
5. Reqd Oil Weight ?
6. Reqd Oil Rating ?
7. Service Intervals:
Light Service ?
Heavy Service ?
8. Location of Oil Pressure Sending Unit ?
9. Oil Pump Type Rotor
10. Oil Pump Location: Located BTM of engine front cover
11.The Oil Pump is Driven by the: Camshaft?
12.OIL Pump Specifications:
13. Oil Pressure at Idle cold: HOT:
14. Oil Pressure at 2000 RPM Cold: HOT:
Light Service ?
Heavy Service ?
You should buy a Haynes manual... has all the specs you are looking for on page 25-27.
FSM = Factory Service Manual. Can be downloaded here: www.xenons130.com
I will have to do that as seen I cannot locate mine. I have chosen to change the vehicle on the worksheet to my pickup. I only hope I can find everything I need.
I saw a built GM 355 at the school and I want it for my Z.
Here's some quick answers for you, from www.google.com and the Haynes manual.
4. Engine size CC/ or CU: 2393cc
5. Reqd Oil Weight? As in all cases... it depends on the operating conditions.
6. Reqd Oil Rating? SAE
Light Service? @ 1000, 3750, 7500, 15000, 30000 miles.
Heavy Service? When needed.
8. Location of Oil Pressure Sending Unit? Passenger side of block, near motor mount.
9. Oil Pump Type: Rotor
11.The Oil Pump is Driven by the: Camshaft? No, crankshaft.
14. Oil Pressure at 2000 RPM Cold: HOT: I don't have exact #'s... but 60psi+ is normal when cold. 30-60psi when hot.
WichitaZRide
Jul 2, 2005 06:55 PM
calvinD
Aug 23, 2003 01:29 PM
