ignition problems
Old Oct 10, 2004 | 04:34 PM
rifleman502's Avatar
ignition problems
allright here we go...
ive evidently fried my ignition system but i dont know where, i took the resistor or whatever it is conecting to the coil out of the loop conecting the 2 wires together, when i turned the key on i heard a loud pop before i could crank the engine.... i opend the fuseable link box (i call it that cause the black wire in there says that) near the battery and it had a little smoke in it still, what do i need to replace in there, the whole box? is there a fuse in there? i need input guys... what started all of this is i was getting a really weak spark to my plugs... all after i changed to a hotter range plug.... *sigh* im havin a really shitty "Z" week, help me please... also i found an electric water pump made specifically for the L series engine, looks promising http://www.csiperformance.com/water_pump3.html
CSR Performance Products- Water Pumps
any help would be appreciated, thanks
Zac
Disgruntled Z owner
Old Oct 10, 2004 | 07:41 PM
duckyz's Avatar
Well, yeah, sounds like you blew a link. Pull each one out and look to see which one's black. If you can't see...smell. Your nose will tell you which one's burned out.
Old Oct 10, 2004 | 09:16 PM
i just found the most ingenious website ever and i found the parts to go with the plans in the walmart car stereo isle, and im gonna share it
how to replace your fusable links with maxxi fuses, its a beautiful idea
http://www.atlanticz.ca/zclub/techti...nks/index.html
its at the bottom of the page
Old Oct 11, 2004 | 01:49 PM
well i got her fixed.... fusable links were fried, did the maxi fuse mod, here is a pic
looks lots cleaner if you ask me
ThaPimpShrimp
Mar 31, 2013 11:45 PM
StylusRose
Jun 19, 2007 02:23 PM
simplyzbest92
15
Sep 13, 2006 05:40 PM
SHADY280
May 16, 2006 05:30 PM
evbball204
Oct 7, 2002 09:32 AM
