Have to pump gas pedal while cranking the car HELP!!!
Old May 30, 2012 | 02:43 PM
ricksilvia's Avatar
My 1983 280z non turbo requires me to pump the gas pedal while cranking the ignition to get it to start... I know its fuel injected... when it is running it doesnt stall or sputter the response time is also go. oil presser is good also.. this is my first Z please helps Thanks in Advance.
Old May 30, 2012 | 04:45 PM
iamericgee's Avatar
I usually just pump very slightly to get mine running then slowly push the pedal more and more until it idles the way i want it too
Old May 30, 2012 | 05:06 PM
Switchtr3's Avatar
Mine's kind of the same too. Usually I don't need to but sometimes I have to tap the pedal ever so slightly when starting it. As long as it runs normal, I'd say it's probably fine. I mean they're pretty old cars after all there's bound to be a few tricks here and there
Old May 30, 2012 | 09:26 PM
Welcome to ZDriver!
Could you give a lil more background on the prob?
When did it start?
Suddenly or slowly got worse?
What have you checked?
Have you done a basic tune up?
Old Jun 2, 2012 | 04:45 AM
duckyz's Avatar
Um... Let me think....(ugh it hurts!)
Fuel Filter, change it. Air filter...same thing. Change it. Doesn't have to be a K&N, just change it.
CHTS plug... (The little thingy between cylinder 5 and 6 below the spark plugs... toward the firewall. Clean the connections.
Of course, a general tune up goes a long way. Try that, see what happens.
Old Jun 3, 2012 | 05:20 PM
ricksilvia's Avatar
the problem has been constant since i got the car i have a hunch its the thermo time valve...? the temp guage on the digital dash also doesnt work
Old Jun 3, 2012 | 06:29 PM
ThaPimpShrimp's Avatar
Probably should check out the temperature sensor before anything else if your temp gauge doesnt work,
Old Jun 3, 2012 | 09:27 PM
^ Yeah I would check that too. I learned the hard way, when I lost a heater hose on the freeway with my T-top. I warped and cracked my cylinder head, because of the gauge not working.
All aside, my Z runs great, just is hard to start also. These cars are notorious for having cold start issues. I really haven't had a Z, which didn't give me problems. When trying to start it. It is just a process of elimination. Welcome to the world of 280zx's. lol Good luck man.
Old Jun 3, 2012 | 09:29 PM
I just realized no one has said this yet but.. Cold Start Valve?
3d_Ryan
May 22, 2016 06:23 PM
dhall1414
May 17, 2012 03:36 PM
MURETO
Sep 13, 2010 03:01 AM
garcia1987
Dec 25, 2009 04:10 PM
ern
Oct 20, 2006 07:01 AM
