fuel injector voltage?
Old Jun 17, 2008 | 06:10 PM
michanic220's Avatar
can somebody tell me what the fuel injector voltage is on a Z car? mines a 280zx 2+2 fast back non turbo. with a L28E engine. thanks -jt.
Old Jun 17, 2008 | 07:49 PM
280zx2by2's Avatar
Haterade by da gallon!
i need motivation to use the search feature, so why do you need this, is it cause you found some injectors in some old volvo or ford or something of the like?
Old Jun 17, 2008 | 11:24 PM
nope, actually one of my injectors are bad and need a test voltage to test them because there plugged up and dont have the money for 6 new ones so im going to unplug them, thanks for being so kind =]
Old Jun 18, 2008 | 06:27 PM
Would it not be 12 Volts? It's OHMs you should be checking.
Old Jun 18, 2008 | 09:02 PM
280zx2by2's Avatar
is it bad or leaking? i cant find the resistance in my chiltons manual...big suprise there...screw you chiltons!!!
Old Jun 19, 2008 | 10:45 AM
car sat for a while and the injectors plugged up. so we have to clean them because i cant aford new ones.
Old Jun 19, 2008 | 03:13 PM
280zx2by2's Avatar
did you try the injector cleaner!!!! im telling you it is the easiest way to clean them and if it doesnt work your out like 2 buks.. if you go your way your out like $8 for seals, $5 for a holder cause the will probly crack, risk messing up the injector more, and theres always the risk it will leak when you get done!!!
but if your good like me you will get the seals to seal on the first try
i replaced all of my injectors for i think $250 to $300...
pete7956
Sep 25, 2013 07:23 AM
cdeshane
Jul 23, 2005 09:58 PM
Gr8White
Jul 5, 2005 04:31 PM
swmoman
Mar 9, 2005 09:17 PM
swmoman
Mar 7, 2005 07:57 PM
