battery charger
battery charger
What is the correct way, to hook up a battery charger to the z's using a (1.5amp) battery tender.....
other than putting the clamps on the battery post.....
will this harm any electrical componets hooking it up this way?????????/
or should you put the ground clamp to the frame instead of the battery post...
thanks hermultra
thanks hermultra
Your car will blow up if you hook up a battery charger!!!! Don't dooooo iiiittttt!!!!!
Just hook it up... + to + and - to - You can hook the neg to the neg battery terminal, or to a body ground. It makes no difference.
Hey, i had no idea either...
http://www.howtodothings.com/automot...r-battery.html
http://www.battery-chargers.com/char...structions.htm
On my battery charger, clamps are colored... so I just hook up red to red and yellow to yellow.
Interesting that on my dads Mercedes, the battery is located under the rear seats so when battery died, he hooked up one clamp to a terminal? somewhere around the engine and the other clamp to the frame... and it started up.
I heard using the old fashioned cables from car to car might possibly not be good for some electrical components... but maybe that's with newer cars.
thanks hermultra
thanks hermultra
Logan8er
22
Jul 12, 2006 11:13 AM
