280ZX Turbo - No spark, no needle bounce.
Old Dec 8, 2012 | 12:58 PM
zedsdeadbaby's Avatar
Greetings all, I guess the title says it all. Drove my car just fine this morning to work. Lunch time rolled around, and my car cranks for days but I get no spark off of the coil. My tach needle doesn't bounce when cranking either, and I'm suspecting that it's the ignition control module. I plan on doing the GM HEI swap at this time. Before I go spend the $30 or so on the parts, should I be looking at anything else here?
Thanks.
Old Dec 8, 2012 | 07:26 PM
Fixed. Skittle's GM HEI DIY is the bee's knees. Took all of 15 minutes, and I have a retarded big blue spark.
Old Dec 11, 2012 | 11:46 PM
hermultra's Avatar
what is a skittle's HEI swap?
Old Dec 12, 2012 | 04:38 AM
77280ZX's Avatar
Its a forum members name "skittles"
Old Dec 12, 2012 | 09:46 PM
You use a GM HEI module to replace the stock turbo ignitor module
Old Dec 13, 2012 | 12:27 AM
hermultra's Avatar
where may I ask is the stock the ignition control module, located on an 83 turbo? my car after it gets hot it just runs rough clears up and just dies
My tach needle doesn't bounce when cranking either, let it set for a few hrs
she cranked so i drove it home about 20 miles @ night... two weeks later drove it about five miles ate breakfast came out 30 min later same thing would not start(My tach needle did not bounce when cranking either. then after about 10min she cranked
will the control module act like this (heatsink) or do they just go out all together.
and what about the crank positioning sensor if its going out will it act like this.
Old Dec 13, 2012 | 08:52 AM
ICM is right next to the coil, can't miss it. It's wired to the + and - side of the coil. They can fail when they get hot, or they can fail at random.
Old Dec 13, 2012 | 10:32 AM
rogerz's Avatar
Grumpy & Helpful
its just a power transistor nothing exotic. takes the place of a set of points in old car ignition systems. you need to make/break the current to a coil to get the spark.
Old Dec 14, 2012 | 12:53 AM
hermultra's Avatar
is their a sertin GM HEI module # that works on the zxt
Old Dec 14, 2012 | 03:35 PM
Tell them you need one for a 1980 Chevette. It's a pretty standard part. If you go in and say, "I need a GM HEI module," they'll probably hand you an Accel or Pertronix part, which is :thumbup:
Old Dec 15, 2012 | 10:19 AM
.... which should be the four pin module...
Old Dec 15, 2012 | 11:13 AM
r2l's Avatar
r2l
I have everything wired up.....which is the "signal wire to ecu"....the blue one or one from the plug (black or white)...going through FSM right now but if someone could chime in quick that would be great...
Old Dec 15, 2012 | 11:18 AM
Skittle's Guide.
Old Dec 15, 2012 | 11:21 AM
r2l's Avatar
r2l
I have that...it has the "yellow wire to ecu" but doesn't say which wire to hook that to. There are the two wires that plug into the old ignitor but there is also a blue wire that has a bullet looking connector...
Old Dec 15, 2012 | 11:46 AM
r2l's Avatar
r2l
Still nothing...guess it's the coil....I can pull the coil wire off and lay it near the shock tower bolt and get no spark....
Old Dec 15, 2012 | 12:39 PM
Did you mount the HEI module to anything? It HAS TO BE GROUNDED through the mounting holes to the chassis. I screwed mine to my shock tower. Skittle made a bracket.
If you don't ground the module itself you will get no spark, and you probably fried the module.
Old Dec 15, 2012 | 01:10 PM
r2l's Avatar
r2l
I mounted it to vented plate with one bolt/lock washer/nut and then the other hole I put sheet metal screw through the module hole through my plate into the engine bay wall. The plate itself is also mounted to the engine bay wall.
The only thing I didn't do was make a ground from the factory "T" black wire w/white stripe to coil...I wonder if that fried the module. I have a friend that has a MSD Blaster Coil I'm going to borrow to see if I can get it to fire...probably take my module back to Autozone to see if they can test it as well...
Old Dec 15, 2012 | 02:00 PM
Try making it EXACTLY as pictured. There's no reason it won't work, its a very simple system.
Old Dec 16, 2012 | 03:31 PM
r2l's Avatar
r2l
Took my HEI module back to Autozone and had them test it, its good. Looks like i'll have to have it towed to my local Datsun guy....
Old Dec 16, 2012 | 06:41 PM
Do this.
Old Feb 10, 2013 | 06:54 AM
hermultra's Avatar
well??????????????? did it fix your issue.....a reply of your finding's would be nice.some of us might have the same issues like (Me) thats why we are here!!
Old Feb 10, 2013 | 11:53 AM
It fixed my issue, which was a bad ignitor. That's all the GM HEI swap is; a cheap fix for a bad stock ignitor.
If you have a no-start condition, always try jiggling your ECU connectors and your injector harness first.
Old Feb 13, 2013 | 04:23 AM
r2l's Avatar
r2l
Sorry for being MIA....works been crazy....did the swap, didn't fix my issue. I had it towed to a local Nissan guy. He says no spark with distributor in car pull it off and sparks like crazy?? He is tracing electrical wires hoping to find issue....
Old Feb 13, 2013 | 10:52 PM
hermultra's Avatar
GM HEI swap worked for mecar is running pretty dam good so far!! thanks everyone
Fairladyz1990AF
Apr 24, 2014 04:15 PM
~KnuckleDuster~
Aug 27, 2013 01:55 PM
Tsuka89
May 27, 2012 02:43 PM
vrocious
Jan 14, 2010 10:02 AM
thxone
Aug 3, 2007 07:17 PM
