Z has a problem :(
Old Aug 27, 2004 | 08:50 AM
tougez's Avatar
Z has a problem :(
Well two days ago I started the Z up and it seemed a bit wierd. I just thought it was because it was a little cold out. Well I got it running and it was going fine, but then later in the day all of a sudden it stalled while i had the clutch in and my foot on the brake. It started right back up but every now and again it will miss really bad almost like a stall but will start right back up if your moving fast enough. I thought it might have something to do with the spark plugs the previous owner put on so i got some NGKs and it hasnt helped. I would appreciate any info people would have. This is a 1983 280zx by the way.
Old Aug 27, 2004 | 09:20 AM
icice9's Avatar
Super Siver & Black Stud
Ignition Module - Very Common Problem In A 20+ Year Old Z... Its The Lil Black Box Located On The Side Of The Distributer...
Old Aug 28, 2004 | 01:49 PM
tougez's Avatar
how much are they new??
Old Aug 28, 2004 | 03:43 PM
duckyz's Avatar
You might want to check out the vaccuum lines as well. Sometimes they get a tiny little crack in them and everything goes to crap in a hurry.
Old Sep 8, 2004 | 05:06 PM
Z*Tech's Avatar
I would believe it's the ignition module too.
Bad news is they will set you back a couple of hundred
Old Sep 8, 2004 | 05:10 PM
tougez's Avatar
Well I was lucky and caught a deal off of a slightly used one from a friend for 20 bucks. You can't beat that with a stick considering they are about 300+ new.
Old Sep 8, 2004 | 05:15 PM
Z*Tech's Avatar
You already had a used one, hope it holds up for you...happy motoring
Old Sep 8, 2004 | 05:18 PM
tougez's Avatar
I figure as long as it lasts me until October when I take the car off the road it will be a good investment. I just couldn't justify spending that much money right now on a little black box. I believe the one on the car was orginal,
unless whoever replaced it used a factory replacement
Myzsucksass
Nov 28, 2013 06:58 AM
turbo84z
Oct 10, 2006 07:30 AM
HybridS130
Sep 2, 2006 05:50 PM
pearly whites
Oct 30, 2003 01:37 PM
saaddaa7
Oct 24, 2003 08:19 PM
