Walbro on 280zx turbo?
Old Oct 10, 2006 | 04:36 PM
xtreme 2's Avatar
Hey guys. I have a 1982 280zx turbo that I am beginning to modify, and one of the things I have always done first with turbo cars is up the fuel. I have an Aeromotive Fuel Pressure Regulator from another car I plan to use, and then I have the Walbro fuel pump from it as well. However, I have heard that the 280zx has an external fuel pump, so how would I use the walbro on this car, seeing as how the Walbro is designed to be intank?
Any help would be greatly appreciated, thanks in advance...
Old Oct 10, 2006 | 04:44 PM
cant....different designs last time i checked...you should be thankfull for an inline fuel pump though they are easy to replace....the intake has a whole assembly and what not, unless you make the 280 an in tank design and complicate things for yourself, then your gonna need a custom fuel pump assembly and then eliminate the inline pump....dont ask me how you can get that done
Old Oct 10, 2006 | 05:47 PM
DarrellBuddy321's Avatar
i am running a walbro 255lph fuel pump. All u have to do is order the external fuel pump.
Old Oct 10, 2006 | 06:25 PM
^^^ yep... just get the external "in line" pump. I'm running one as well... but honestly haven't seen a difference.
Old Oct 10, 2006 | 06:30 PM
he probably knows that...he is asking if there is a way to use his current in tank fuel pump on the Z......i think thats what he is asking...
Old Oct 10, 2006 | 06:38 PM
Dude... you're so smart! There's a couple guys that have done Z32TT in tank pump swaps for the 280zx... tho I don't know how (or why) they did it....
Old Oct 10, 2006 | 06:39 PM
xtreme 2's Avatar
k, so going through the trouble to do the walbro is really pointless? I noticed a diff on my other cars, but if you guys are saying that it isn't making a diff at this point then I'll just install the fpr and call it good...
Old Oct 10, 2006 | 06:44 PM
jfairladyz's Avatar
whats the flow rate on the stock turbo pump anyways? That, combined with how much boost you plan to run will tell you if you even need to upgrade the pump.
koprutzxt
Aug 2, 2012 11:55 AM
DUBAUDIO
Feb 1, 2012 07:47 PM
ern
Oct 20, 2006 07:01 AM
280ZX_AV8R
Sep 30, 2005 02:37 PM
SoulZ31
Nov 21, 2003 12:22 AM
