Turbo performance advice
Old May 9, 2016 | 02:38 PM
JayDV3's Avatar
I have the original factory turbo on my '83 280zxt. I was hoping to get a little more HP and torque after a couple of exhaust improvements and tuning adjustments on a dyno. I do have a new direct wired fuel pump. No intra-cooler.
OLD# New#
2600 RPM
HP 71 80
Ft/Lbs 140 160
4000 RPM
HP 132 138
Ft/Lbs 169 180
5000 RPM
HP 150 163
Ft/Lbs 137 160
Old May 9, 2016 | 04:26 PM
rogerz's Avatar
Grumpy & Helpful
is there a question there or are you just bragging? put in a boost controller and run your boost up to 10 psi youi will see a real HP increase. 163 HP is laughable. stock out of the box on an n/a is like 145 I believe the turbo was like 180 so you aren't even better than what was.
Old May 9, 2016 | 08:31 PM
JayDV3's Avatar
I was just looking for advice to improve performance, and listing the dyno results were, and yes I thought it was close to what was supposed to be, but the "old" numbers were lower than what factory was. A boost controller and intra-cooler were suggestions, but I didn't know if the factory turbo is designed for intra-cooler, or even if it was kaput and needed replacement.
Old May 9, 2016 | 10:25 PM
rogerz's Avatar
Grumpy & Helpful
intracooler is nice but not necessary as I doubt you are intending to build a 300+ HP monster L28. put a boost controller on it and you will notice a big difference as did I when I Boosted my 81. 45 bucks and some hose will do it. and a lot easier to install than on a Z31.
Old May 10, 2016 | 05:38 AM
JayDV3's Avatar
yes, not 300+HP. Wifey just likes to zoom and enjoys acceleration. I'll give that a try, thanks.
Old May 10, 2016 | 06:56 AM
Remember to remove the emergency release valve (POV) from the intake... otherwise the only thing it will do is chirp and jerk like a chipmunk on steroids.
You will also need a boost gauge because the stock one isn't going to tell you anything over stock boost, so you won't know where to set it.
Other easy things would be to swap to the Z31T ecu / maf, ignition upgrade, and INTERCOOLER (not intracooler).
Old May 10, 2016 | 08:11 AM
JayDV3's Avatar
Thanks Nismo. These tips satisfy my yearn to learn. Intra/Inter Within/between I always mix them up.
kiboy6
May 18, 2008 09:36 PM
pete8717
Nov 6, 2005 02:24 PM
Texaz
Oct 26, 2005 08:42 PM
zr8d
Mar 21, 2004 11:54 PM
79280zx
Apr 20, 2003 10:35 PM
