temp gauge
Old Oct 28, 2007 | 03:39 PM
82zxturbo's Avatar
Question temp gauge
its not working and i cant find where it goes, and i just replaced the intake and exhaust gasket, and i am only getting 3 1/2 psi
Old Oct 28, 2007 | 06:22 PM
The temp sensor is on the bottom front of the thermostat housing. Two wires from the injector harness run to it and another sensor on the housing. The temp sensor should be the one w/ a pigtail wire coming from it.
As for the psi prob... are you using an aftermarket boost gauge?
Old Oct 28, 2007 | 10:41 PM
82zxturbo's Avatar
no, boost gauge is stock
Old Oct 29, 2007 | 12:13 PM
The stock boost gauge doesn't measure in PSI, it measures in mmHG.
Old Oct 29, 2007 | 02:05 PM
82zxturbo's Avatar
well before i changed the intake/exhaust gasket it would get all the way up to 7, now it doesnt even get half of that
Old Oct 29, 2007 | 07:17 PM
Does the car run any slower now?
Old Oct 29, 2007 | 08:59 PM
duowing's Avatar
NisTuner
I bet when you did the intake/exhaust gasket you did something similar to what I did, and messed up the wiring for the thermostat and either forgot to hook up a vacuum line, or hooked up the whole VCM in the wrong order.
Old Oct 29, 2007 | 11:07 PM
82zxturbo's Avatar
the temp gauge wasnt snapped in all the way, the car does run a little slower, but all the vacuum lines and wiring is correct because i marked everything, its just being a pain, and now its leaking trans fluid very bad, and its dripping around the starter because it is soaked in it
Old Oct 30, 2007 | 09:28 PM
duowing's Avatar
NisTuner
Your gauge shouldn't ever read 7 if everything is stock. For starters there is that red band in boost, it will only ever hit the beginning of that red band unless you modify it. Also check your ignition timing for the car feeling like it's running slower, also go through and check every vacuum line. Even if they're hooked up correctly, some may be cracked. It wasn't until I did my Intake/Exhaust gasket that all my vacuum lines started cracking and breaking, mainly because I had to pull alot of them off.
freek bachman
Dec 31, 2013 05:29 PM
gridez31
Feb 28, 2010 10:11 AM
ASA240z
Sep 21, 2009 02:44 PM
jfairladyz
May 6, 2005 01:49 PM
RED-Z-1
Aug 14, 2003 11:46 PM
