Speedometer problems...HELP!
Old Jun 13, 2007 | 08:59 PM
BhamZ1982's Avatar
Hey, i have a 82 280zx and everytime i drive it the speedometer seems to be off by 10 MPH...i have no idea why...what should i do?
Old Jun 13, 2007 | 09:01 PM
flightforlife07's Avatar
do you have different than stock tires... taller or short tires always affect your speedometer unless you get it recalibrated
Old Jun 13, 2007 | 09:02 PM
^^^ Indeed... diff size tires or differential swap (mis-matched diff ratio to speedo calibration) can throw it off.
Old Jun 14, 2007 | 07:44 PM
BhamZ1982's Avatar
well i the stock tires are p195 and i just bought brand new p205....should i take it to a mechanic..? or what do i do?
Old Jun 14, 2007 | 08:19 PM
If you put on bigger or smaller tires than stock, you change the circumference of the tire, which means that the tire actually covers a different distance per revolution than stock... check out this nifty lil tire calculator: http://www.miata.net/garage/tirecalc.html
Plug in your stock tire size & then the new tire size. Going from 195 to 205 shouldn't make a 10mph difference, but it will be off a lil. Are you sure it's 10mph off?
Old Jun 15, 2007 | 01:21 AM
jfairladyz's Avatar
when i switched to my 130mph speedo because my son destroyed my 80mph'er I had the same issue. My speedometer was always off by quite a bit, even at lower speeds. 10-15mph difference in actual speed and what my speedometer was reading was the norm. The faster i went the further off it would be.
Old Jun 21, 2007 | 07:34 AM
rogerz's Avatar
Grumpy & Helpful
there is a gear in the tranny that needs to match the rear end to get the correct speed on the speedometer. If someone switched rear ends or the gear in the tranny you will have this problem. But it should be a linear change in speed ie if 10% off it will always be 10% off not 10 mph off. So are you saying when you are doing 30 your speedo reads either 40 or 20 depending on which way it is off. If that is the case sounds like the needle was put on the speedo shaft off by 10 mph.
Lucky91647
May 11, 2013 09:24 AM
mckenzig
Aug 24, 2007 03:33 AM
flightforlife07
Jun 13, 2007 09:04 PM
newb81280zx
Nov 29, 2004 08:56 AM
Lion00
Sep 23, 2003 07:36 AM
