running hot 280zx 83'
Old 11-26-2012, 08:25 PM
ricksilvia's Avatar
my 83' 280zx na is running about 2/3's of the was up my temp gauge??? why?
ricksilvia is offline
Old 11-26-2012, 09:45 PM
Mebbe there's no coolant in the radiator...
NismoPick is offline
Old 11-27-2012, 07:33 AM
ricksilvia's Avatar
Coolant is full goes up to 3/4 s then back down to half
Old 11-27-2012, 07:55 AM
The gauge can be faulty or off. Get the FSM and make sure your temp sensor is reading correctly. If it goes to 3/4 then back down to half is that your thermostat opening?
FricFrac is offline
Old 11-27-2012, 08:29 AM
Infrared thermometer will tell you right away what's going on. Measure temp at thermostat housing, and again at the bottom radiator outlet. Should see a 20* to 30*F drop.
Old 11-28-2012, 07:32 AM
Red280zx's Avatar
I would personally just pick up a new thermostat. It doesn't take too long for those to go bad.
Red280zx is offline
Old 11-28-2012, 06:12 PM
ricksilvia's Avatar
Marc the IR thermometer gave me a reading of 245 degrees fainthearted in the general vicinity of the thermostat housing. Thoughts? also is this on par with the gauge reading of 2/3's to 3/4's. the car was raised to that temperature at an idle, but according to my gauge it is also the same temp as when im driving.
thanks for all the help
Old 11-29-2012, 08:10 AM
245*F is hella-nuts-hot! You sure you weren't getting a reading from the exhaust manifold???
It shouldn't be any hotter than the thermostat rating (usually 170* to 190*). Time for a complete coolant flush, replace the thermostat, and yank the radiator and do a full flush too.
Pay attention to what the coolant looks like when you drain it.
Old 12-09-2012, 07:28 PM
aruiz714's Avatar
I have the same problem its on 3/4 of the gauge. No more no less unless I'm on the freeway. Update on the fix?
aruiz714 is offline
Old 12-09-2012, 09:17 PM
Like I said up above get the FSM and measure it. The meter will tell you if it's the gauge or the sender or something in the harness. Starting to sound like the gauge from your other thread...
FricFrac is offline
GNRick
07-10-2014 07:12 PM
steady88
04-23-2013 08:29 AM
Ratfink
08-11-2008 12:37 AM
iluvJDM
03-31-2007 03:50 PM
Quick Reply: running hot 280zx 83'
