Hope and questions for my 280 turbo
Old 05-18-2005, 07:05 AM
MetalZ's Avatar
Alright; my 82 turbo started yesterday! One problem. It started while my dad held the afm open. So it seems to me that it's either getting too much fuel; or not enough air; or not enough spark. Any suggestions? And it smokes.The smoke smells of gas.
MetalZ is offline
Old 05-18-2005, 07:09 AM
Bleach is my Hero
s/cL3.0's Avatar
How does it idle?? I would adjust the AFM and lean it out a little and go from there.
s/cL3.0 is offline
Old 05-18-2005, 07:19 AM
DoTheDrew888's Avatar
Maybe you need a new AFM.
DoTheDrew888 is offline
Old 05-18-2005, 12:59 PM
whyfeel's Avatar
Does anyone know of any AFM that can just be dropped in without changing the FI ECU that is less restrictive than the flap-type used in the 280ZX?
whyfeel is offline
Old 05-18-2005, 02:05 PM
Externally Wastegated
lifegrddude's Avatar
Not that I know of. Closest thing to "drop in" is the Z31 MAF and ECU swap. You can try messing w/ a BMW afm or maybe an MR2's afm, I believe both used the flapper door style afm, but you'll be kinda on your own. No one I know has done that swap.
lifegrddude is offline
Old 05-18-2005, 02:18 PM
Dorifto's Avatar
Perhaps someone with machining experience can fab up a larger unit that still uses the stock guts ...
Dorifto is offline
Old 05-18-2005, 02:58 PM
80's BMW 325i I heard was larger. I haven't checked yet. They use the same flap AFM for the same type of FI system.
Bleach is offline
Old 05-18-2005, 04:14 PM
lww
Head Muckraker
lww's Avatar
Originally Posted by Bleach
80's BMW 325i I heard was larger. I haven't checked yet. They use the same flat AFM for the same type of FI system.
Actually, this was a way to cheat in SCCA racing back in the 80's. ZX racers would swap the AFM from the BMW 325 that has a bigger opening, but looks exactly like the stock AFM for the 280ZX so it wouldn't be caught at Tech.
It's a bolt on swap, but you'll need to adjust the AFM for the greater air flow.
lww is offline
Old 05-18-2005, 05:03 PM
whyfeel's Avatar
Interesting... Do you know if the plug matches up? Or do you have to do a little rewiring.
whyfeel is offline
ever888
26
09-17-2007 09:50 AM
dmitry
09-22-2005 08:26 PM
ThermalWake
08-10-2005 08:51 AM
mewfis138
05-23-2005 11:56 AM
strictlyzx
07-18-2004 05:34 PM
Quick Reply: Hope and questions for my 280 turbo
