I hope it's not been done to death
Old Jul 27, 2007 | 12:32 PM
ever888's Avatar
I will summarise what I think is right to allow you readers to say yeas or no to whether or not options are possible.
looking to fit a manual box to a 300zxTT engine for a kit car project
have read that
you can fit a nat asp 300zx (Z32) box to the TT engine if you use washers to space the starter motor out a bit to align with ring gear teeth and grind a couple of mm out of the gearbox housing to accomodate the TT's larger flywheel.
Or
fit the nat asp Z32 box using the flywheel off the nat asp engine using nat asp starter but clutch would need to be uprated to make way for the TT's power.
Or
fit a manual TT box
I presume all options are possible as I begin my search for a manual box.
please read through and advise for or against please.
thanks
to all contributers
Old Jul 27, 2007 | 01:15 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
wtf did you just say?
Old Jul 27, 2007 | 01:33 PM
ever888's Avatar
perhaps your not the Encyclopedic Knowledge you call yourself by
Old Jul 27, 2007 | 01:44 PM
SpeciallySpiked's Avatar
I'm a Registered User!
just stick with the TT box, it'll be easier and it was sorta designed for the engine...
However, I have no clue what a nat is from or what it is for that matter.
Old Jul 27, 2007 | 02:00 PM
ever888's Avatar
naturally aspirated i.e no turbo
sorry if this confuses but int the UK it's commonly used.
Old Jul 27, 2007 | 02:17 PM
ahhhh, that was my first guess but I didn't trust myself.
We usually say na or N/A. Makes sense though (nat).
Sadly, I don't know the answer to your questions of fit. Hopefully someone else can come and help out.
Old Jul 27, 2007 | 02:24 PM
Riz Z Speed's Avatar
Administrative Brown Guy
Yes u could do it that way or just shave some metal off of the bell housing to clear the flywheel. it won't have an adverse affect on the mounting strength like shims or washers would.
this won't work as a TT clutch wouldn't fit on the NA flywheel and I haven't seen high torque clutches for the NA.
fit a manual TT box
Best bet is to use a TT tranny as this will be the easiest way. Straight bolt on with no fitment issues or lack of clutch options.
I think that's all your questions.
Old Jul 27, 2007 | 03:56 PM
ever888's Avatar
cheers guy's for your efforts and sorry about early confusion.
I think your right with the TT box but they are thin on ground over here and sometimes cheaper to buy a damaged car to break for bits.
the naturally aspirated models here are also not as popular so I'm just trying to widen my search for a good but cheap gearbox.
Old Jul 27, 2007 | 10:22 PM
The title was given to me by the moderators of this site. If you don't think it fits, take it up with the members and moderators.
And it's not that I don't know how to answer your question... I don't know how to read improper acronyms. "nat asp"... wtf is "asp"?
Old Jul 28, 2007 | 02:06 AM
ever888's Avatar
my reply was a tough in cheek as WTF but I'm not going to argue
your obviously quite sensitive so I leave you in time to get over it
relax
Old Jul 28, 2007 | 02:24 AM
if you are going to use acronym's use ones that are widely used, for non turbo use NA for radiator use rad. for crankshaft use crank, for transmission use trans. or gearbox...etc
it will make EVERYBODY'S life ALOT EASIER
Old Jul 28, 2007 | 03:14 AM
relax
You obviously know nothing about me, yet you act as if you do. lol
Old Jul 28, 2007 | 01:31 PM
MikeZ's Avatar
................lol, hehe
Old Jul 29, 2007 | 05:39 AM
Comorat2x2's Avatar
I Can Pee Farther Than Any Of You!!!
Old Jul 29, 2007 | 06:55 AM
akz31's Avatar
He was using the acronym he was knows... I understood all of the acronyms he used guys i dont know what the big deal is... just a little commen sence and some problem solving is all it should take to figure out a term not familiar to you. not his fault
Old Jul 29, 2007 | 10:06 AM
Murph Z32's Avatar
Prove it.
Old Jul 29, 2007 | 11:03 AM
no he missed some letters, i could for the most part figure out the acronym's but he also at times typed worse than..... well, me!
and comorate, let us not get into a pissing fight. but he got his answer so maybe we shouldnt argue over who is right, the UK or the US.....
Old Jul 29, 2007 | 05:44 PM
260zturbo's Avatar
Stupid Hurricanes...
someone out did snw.......wow waiting for pigs to fly jk jk
Old Jul 29, 2007 | 08:21 PM
MikeZ's Avatar
U-S-A!
U-S-A!
U-S-A!
j/k lol
Old Jul 29, 2007 | 09:17 PM
entropy31's Avatar
The Cake Is A Lie!
ok, back on topic.
Old Jul 30, 2007 | 08:56 AM
scott_91tt's Avatar
Agreed. I understood the post perfectly well. I don't understand why people get hung up on semantics. Big deal...
FWIW - My suggestion is to buy a TT gearbox. I called Z1 Motorsports and they have used TT MT's on the shelf for $750. They guarantee them for 30 days. I am thinking about buying one and attempting to rebuild it myself with new bearings and syncros. My transmission has some bearing whine in 2nd and 3rd (sounds like straight-cut gears) and I'd rather just have a good transmission, built & ready to go. Thoughts?
Old Jul 31, 2007 | 11:13 AM
MikeZ's Avatar
Well how much is a brand new transmission? Would it be more to rebuild one than just get a new one?
-'cause i've never seen a site selling syncros, bearings, etc(you probably have).. So i have no idea what the cost of a rebuild is. Courtesy nissan sells new tt trannies for around $2000.
Old Jul 31, 2007 | 11:19 AM
entropy31's Avatar
The Cake Is A Lie!
you can get a '98+ spec TT trans for about $1900 from CZP. the '98+ spec had the better synchros.
Old Jul 31, 2007 | 11:22 AM
MikeZ's Avatar
forgot about good ol' CZP
Old Aug 1, 2007 | 01:00 PM
scott_91tt's Avatar
I did not know this... I think I'd rather have a brand new one than rebuilding one. Parts to do a basic overhaul (gaskets, bearings, syncros) are about $600.
