Fuel Sending Unit screen/filter
Old Sep 6, 2005 | 08:30 AM
Carl's Z's Avatar
Has anyone changed this?? Has it made a difference when you did??
Thanks
Old Sep 6, 2005 | 08:38 AM
EatmyDust's Avatar
I havn't, but when you buy a new pump don't they come with the screen, or am I thinking of somthing els. I know on my jeep it did.
Old Sep 6, 2005 | 09:43 AM
Carl's Z's Avatar
No, this is actually in the tank on the end of the pick up tube...
Old Sep 6, 2005 | 10:25 PM
jfairladyz's Avatar
Carl, unless you got a lot of sediment or anything else floating around in your tank, the screen shouldn't be blocked up. If your Fuel pressure is reading normal then chances are you're alright. Now if the pump was straining away and you weren't getting any pressure then I would suspect a blocked pickup.
Old Sep 6, 2005 | 11:06 PM
EatmyDust's Avatar
Yea thats the screen I was thinking about, but the pump is located inside my tank on the jeep. THis is not a jeep forum so this dose not matter.
Old Sep 19, 2005 | 11:31 AM
nismo619's Avatar
Personal i have tooking out my fuel sending unit and mine was cloged so i used some CLR calicum lime an rust and a soft brissle tooth brush and a little water and she cleaned right up be very careful the screen is very thin..
1982 280zxt
1993 300zx
houlis1211
Feb 24, 2013 07:04 PM
HexaggramJDM
Jun 29, 2011 10:37 PM
rjc280z
Sep 29, 2009 01:13 PM
Carl's Z
Sep 12, 2005 04:53 PM
ratedZ
May 26, 2001 07:58 PM
