Fuel Sending Unit screen/filter
Carl, unless you got a lot of sediment or anything else floating around in your tank, the screen shouldn't be blocked up. If your Fuel pressure is reading normal then chances are you're alright. Now if the pump was straining away and you weren't getting any pressure then I would suspect a blocked pickup.
Personal i have tooking out my fuel sending unit and mine was cloged so i used some CLR calicum lime an rust and a soft brissle tooth brush and a little water and she cleaned right up be very careful the screen is very thin..
1982 280zxt
1993 300zx
1982 280zxt
1993 300zx
